Question about GE Washing Machines
I need to replace the timer on my GE Washer Model WPXQ3090T2WW. I understand that the knob is held on by a clip. How do I get that off?
  • 999 Answers
Pull the knob out and use a very small screwdriver to push the clip off or a long thin pair of needle nose pliers to pull the clip off.
Eric
Posted on Jun 20, 2009
I have a GE top load washer model #WJRR4170GWW. When I attempted to change the load size from large to super, the knob broke and came off the control panel. Now there is just a hole on the control...
themobilian_130.jpgThe new part has a clip in it that holds it to the shaft of the timer. Installing it is so easy. Just slip the new knob on the shaft of the timer. IF the shaft is still on the timer. Did you mean the shaft came out of the timer? In that case you would need a new timer.
Nov 13, 2010 | GE Washing Machines
The dial to select wash cycle (GE top load washer) seems loose. It is difficult to turn, as if something is not engaging. Any suggestions?
The knob wears out and won't grab. It is easy enough to replace if you know the trick. Take pair of tweezers and remove the clip behind the knob, just push on the replacement knob and oil the timer then move the timer around several times to help the shaft turn easier.b8e8a25.jpg
May 02, 2010 | GE WBSR3140DW Top Load Washer
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
Timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Dec 08, 2008 | GE WBSR3140DW Top Load Washer
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Sep 13, 2007 | GE WBXR2090B Top Load Washer
Washing Machines Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
