Question about Snapper Garden
How to hook up clutch cable on snapper mower
How to route and connect clutch cable from pedal to clutch assembly
  • 28 Answers
SOURCE: snapper mower electric start problem
On most mowers, that red wire will connect to the battery. that could be your problem.
you didn't say if it is a rider or not, or how old it is.
Touch the wire to positive post on the battery, with the key off, remove quickly if it sparks.
if no spark, hold it to the battery while turning the key.
if the engine tries to start, connect it permanently.
Posted on Apr 14, 2009
Geologist71
  • 25 Answers
SOURCE: I have a question about a '94 Geo Metro clutch cable
First you must loosen where the cable goes to the tranny and it will give you moor playing room when connecting it .
You cannot connect it from under the hood it must be done from under the dash.
Be sure to push the seat all the way back.
Posted on Jul 15, 2009
  • 68 Answers
SOURCE: CLUTCH STUCK
try fitting a new cable the old one can be sticking in the casing these cable"s do have problems with worn inner cable tubes
Posted on Aug 08, 2009
  • 811 Answers
SOURCE: Need diagram of routing for the clutch cable
check connection at or right before clutch connection point
Posted on Oct 04, 2009
  • 165 Answers
SOURCE: clutch cable connected to pedal assembly broken or disconnected
I have never seen a cable operated clutch on this model, only hydrolic, with a master cylinder and slave.
Posted on Nov 03, 2009
Mower deck belt routing diagram for snapper mower model YT16D414B
Request the mower deck belt routing diagram directly from Snapper.
Jul 09, 2017 | Snapper Garden
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Replace clutch cable
Hi, I know where you can get that part.
Try ProParts Direct Snapper ProParts
Sep 28, 2013 | Briggs & Stratton Snapper 5900748 355Z...
Need to adjust rubber drive clutch on 30 inch snapper mower
there are small metal beads on the cable near the pedal you move to the other side of the pedal if the friction wheel is warn you will need to replace it only 3 nuts hold it on just flip the mower up on the rear bar and take it off no fancy tools needed
Jun 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
Lurching Riding Mowr
the snapper rear engine rider uses small links on the pedal end of the cable add or remove links from each side of the pedal
Apr 18, 2012 | Snapper Garden
Put a new clutch cable on my escort but no good as i can not adjust the pedal
LIFT THE CLUTCH PEDAL TO DISENGAGE THE ADJUSTING MECHANISM.THIS MUST BE DONE DURING CABLE INSTALLATION AS FAILURE TO DO SO WILL RESULT IN DAMAGE TO THE SELF ADJUSTER MECHANISM.INSERT THE CLUTCH CABLE THROUGH THE DASH PANEL AND THE DASH PANEL GROMMET.( WARNING ) BESURE THE CLUTCH CABLE IS ROUTED UNDER THE BRAKE LINES AND NOT TRAPPED AT THE SPRING TOWER BY THE BRAKE LINES IF EQUIPPED WITH POWER STEERING ROUTE THE CABLE INBOARD OF THE POWER STEERING HOSE.PUSH THE CLUTCH CABLE THROUGH THE INSULATOR ON THE STOP BRACKET AND THROUGH THE RECESS BETWEEN THE PEDAL AND THE GEAR QUADRANT.LIFT THE CLUTCH PEDAL TO RELEASE THE PAWL ROTATE THE GEAR QUADRANT FORWARD AND HOOK THE CABLE INTO THE GEAR QUADRANT.INSTALL THE CLUTCH SHIELD ON THE BRAKE PEDAL SUPPORT BRACKET.ON THE TEMPO OR TOPAZ INSTALL THE PANEL ABOVE THE CLUTCH PEDAL.USING A PIECE OF WIRE CORD OR TAPE SECURE THE PEDAL IN THE UPMOST POSITION.INSERT THE CLUTCH CABLE THROUGH THE INSULATOR AND CONNECT THE CABLE TO THE CLUTCH RELEASE LEVER IN THE ENGINE COMPARTMENT.REMOVE THE DEVICE USED TO TEMPORARILY SECURE THE PEDAL AGAINST ITS STOP.ADJUST THE CLUTCH BY DEPRESSING THE CLUTCH PEDAL SEVERAL TIMES.INSTALL THE AIR CLEANER.
May 31, 2010 | 1995 Ford Escort
Clutch cable connected to pedal assembly broken or disconnected
Nov 01, 2009 | 1991 Nissan Pickup
Oct 04, 2009 | Volkswagen Cabriolet Cars & Trucks
I need a drawing of the gear arrangment of a snapper lawn mower model number 3011x6s
Displaying Smooth Clutch Assembly parts for the Snapper 3011X6S 30" 11HP Extra Tough Rear Engine Rider Series 6:
Sep 20, 2009 | Garden
May 12, 2009 | 1994 Geo Metro
Garden Logo
32 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
