Question about Polaris 1-516-03
Noisy gasket gasket is making the unit noisy
    Top Expert:
  • Polaris Master
  • 5,775 Answers
Need new wall fitting
Posted on Oct 07, 2017
What is the cause of noisy engine
What kind of noise? Inside an engine there are pretty heavy explosions taking place and they tend to be very noisy, which is why an exhaust system is fitted. The task of this system is to cool down the exploded gases and allow them to lessen their pressure before bringing them in contact with the cooler air outside. If any part of the exhaust system malfunctions, the engine will be noisy.
This system consists of the exhaust manifold, which is bolted directly to the cylinder head and sealed with a manifold gasket, The first exhaust section is usually bolted to this with a flange, which has a gasket or ball and socket seal.
Check the gaskets and check for cracks. After the first exhaust section you will usually find either the second section or the muffler, which allows the gas to expand. Check for cracks or breaks in this unit. From there a further pipe goes to the rear of the car, or in some cases to a resonator box which looks like a second muffler. This has to do with tuning the frequency of the exhaust gases to allow a free flow of exhaust gas at cruising speed to enhance fuel consumption. Check here also for cracks, breaks.
Another kind of noise from the engine could be knocking, which could mean serious engine trouble. If this is the noise you hear, take it to a repair shop immediately.
Sep 27, 2014 | Cars & Trucks
Noisy Hayward Vari-Flo Valve Model 710xr50
I HAVE TO ADD MY TWO CENTS! THANK YOU TO THIS WEBPAGE- I had air and gurgling coming from my Hayward Variflo - I sealed all the leaks, and had crystal clear sight glass on my pump, but it still gurgled- I never in a million years suspected too much OUT flow- and it is the easiest thing to test- just cover one of the outputs to restrict the flow back to the pool, and listen- my noise died right down.
THANKS GROUP
Sep 16, 2012 | Pool & Spa
We just bought a used True GDM26 that works but it is too noisy
NONE. This is a common complaint from customers who buy commercial units for use in residential atmosphere or quiet stores. These units are made for noisy commercial kitchens, convienience stores, etc.
May 19, 2010 | True GDM-26 Refrigerator
Tear in gasket and very noisy
they have a better gasket for the waher wh08x10036 not the easiest thing to install
Jul 03, 2009 | GE Energy Star WCVH6260F Front Load Washer
Oil leak from rocker box on 1996jeep cherokee2.5td
Get you a new gasket for the rocker cover, make sure you clean the mating surface good,and all traces of old gasket, and silicon etc. make sure you dont overtighten the bolts to the rocker cover. the torque for the rocker cover is 35 in lbs (4nm). as far as vavle clearance it is none adjustable. A clicking valve can indicate worn lifters, sometimes an oil change will quiet down noisy lifters. If noisy lifters persist you would have to service the heads. If you decide to do that yourself you can ask for a procedure on that too later on. Removal of the head is very difficult, because you need to remove a lot of things, and require you to do a timing on the engine.
Jul 01, 2009 | 1996 Jeep Cherokee Country
I have a punto 55 M reg
10\40 oil ,before changing oil put an engine flush in the engine,then change oil and filter.the noise sounds like noisy tappets,the oil leak unlikely to be head gasket unless u are losing water
Apr 29, 2009 | 2006 Fiat 124
Noisy winsheild
u might have a crack or air getting in to a gap some were?
Sep 04, 2008 | 2004 Pontiac Grand Prix
Polaris 1-516-03 Logo
41 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
