Question about HP DesignJet 1050c InkJet Printer
How to reset the counter ink tube in hp designjet 1050c
kipfixer
  • 5 Answers
SOURCE: configure of hp designjet 1050c
Manuals for the driver and plotter setup can be found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=24023&lang=en&cc=us
Posted on Aug 31, 2009
  • 96 Answers
SOURCE: HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Posted on Sep 09, 2009
brett207
  • 231 Answers
SOURCE: does the HP DesignJet 1050c plotter have a counter?
This data is printed out on the Service Configuration Print
  1. Load the plotter with media.
  2. When the device is 'Ready' scroll the menu to the Printer setup options and press Enter.
  3. Once in the 'Printer Setup options' menu, use the arrow keys to scroll to 'Utilities', and press Enter.
  4. In the Utilities menu, use the Arrow key to scroll to 'Test Prints' and press Enter.
  5. Use the arrow key to scroll to 'Service Config' and press Enter to print the Service Configuration Print.
You should find the data you are after under the heading of Maintenance on the printout
Good Luck!
Posted on Dec 07, 2009
SOURCE: I replace the black ink
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Posted on Feb 08, 2011
vinay229229
  • 1121 Answers
SOURCE: HP DesignJet 1050c plus InkJet Printer hangs up on
Take print out of configure page, check the usage of paper axis, spit on,carriage,service station, and others includes FW.. identify which was crossed beyond 100%,replace them..update FW..confirm once be fore replacing the spares...
Posted on Oct 06, 2011
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050c system error 0A0050
0A0050 indicates a leak in the tube system has been detected. Can be caused by condensation, but more likely the tubes are leaking and need to be replaced.
Sep 01, 2014 | HP DesignJet 1050c plus InkJet Printer
Ink tube reset
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP DesignJet 1050c InkJet Printer
1050c DESIGNJET REPLACE MAGENTA ISSUE
one of the first signs of a faulty power supply is a washed out display,
also you may hear a slight buzzing noise,
you may need to replace the ISS Pwb ( part of the tubes ) not order able separately,
it has been known that the connector block ( for ink Cart) does fail, I would try swapping it with another colours and see if the fault follws the connector block,
it may just be a bad chip on the ink cart.
Jun 07, 2013 | HP DesignJet 1050c InkJet Printer
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Does the HP DesignJet 1050c plotter have a counter?
Good Luck!
Dec 07, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
