Question about Garden
I have an old (I believe at least 25 year old) Remington chainsaw purchased at Sears. When it runs, it runs great but I am having trouble adjusting the High, Low and Idle screws. Could you please advise me on how to properly adjust these. I guess I have to screw them all the way in and then back them off but I am unsure how much to turn each screw out. Thanks for your help - long live my lovely old Remington. Fran Kelly fdk356C@msn.com
    President:
  • 2,187 Answers
Hi
Remember always to never exceed the limits of the plastic limiters during adjustments and do the adjustments once the engine is warm.
For the idle screws increase the richness but watch out for flood coming in early in the starting process. If this happens then the idle is too rich or the engine has low speed.
You can adjust the idle speed by turning the screw all the way in to the stop and then back out around 4 1/2 turns which should be a good place sto start. You can then do minor adjustments after.
You can adjust the fast idle until the engine runs without the chains moving. Adjust clockwise to increase speed and counter clockwise to decrease. Have the engine accelerate and watch for stumbling and smoke then fo to the low speed mixture for further adjustments.
For the low speed mixture turn clockwise with 1/16 turns as increments. Remember to keep 1/16 turns at a time. Adjustments for this screw is more sensitive and you may miss a turn which may be more effective.
Posted on Jun 20, 2009
Fuel ratio for remington mighty mite and user manuel
Most saws are 24 or 25 to one mix on regular 2 stroke oil. Don't use engine oil, use proper 2 stroke oil for clean running. Check the can/bottle for mixing ratio.
Dec 05, 2014 | Remington Garden
I purchased two MS2-200 models, and both arrived dead. Is it that this model is so old that the battery could've died just from old age? I'm now on the hook for a second shipping charge, and a 15%...
These models were discontinued several years ago and it is possible that the batteries are dead from age.
If it is this model type that you like, you may want to purchase a corded model instead. Corded model simply plug into the wall and run from the cord. You will find this type at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/remington-ms2100-microscreentct2-shaver-factory-refurbished-p-395.html
Dec 05, 2010 | Remington MS2-200 Electric Shaver
No chain tesion adjustmen older (yellow) Remington EL.1 chain saw
just undo the singe nut slightly the pull so chain tightens then re tension the nut....about all you can do on those old models.
Jul 24, 2010 | Remington Garden
I am unsure of what kind of oil to put in my 12" chainsaw(electric)?
Well, if it's electric it doesn't need the 50:1 or 25:1 gasoline to oil ratio 2 cycle oil.
It needs bar chain oil , which is thick and lubricates the chain. Only this kind of oil is required for your chain saw.
Remember to adjust the tension on your chain.
Jun 22, 2010 | Remington Electric Chain Saw
Chainsaw won't start
These saws seem to have chronic motor brush problems, and because Remington saws has gone out of business, parts are nearly impossible to find. If you have a broken brush, you may be able to substitute one from a drill or other light tool. Good luck!
May 20, 2010 | Remington 16" Electric Chain Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Electric pole saw Model 106890-02. Chain oil
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. I can only suggest an Internet search for "Remington YourPartNumber". Does it make sense to invest more money in an obsolete item? Eventually a part you need will not be available. Invest in a name brand you expect to be around for at least 10 years. Name brand saws are better constructed than was Remington IMO, and need fewer parts over the long haul. Sorry. Lou
Mar 16, 2010 | Remington Electric Chain Saw
Chain is off and I am not sure how to get the adjusting screw in
You don't need the adjusting screw, if it is missing, you can still run the saw. Get the chain straightened out on the blade, with the cover on if you can, keep the cover bolt loose, put the blade in a vise, pull on the saw and tighten the cover bolt at the same time, make sure the chain moves, as long as it is not dangling down real loose, you should be all set. My adj screw bit the dust years ago, so did the safety bar. Still works great.
Feb 20, 2010 | Remington Electric Chain Saw
Unable to find place to buy chain adjuster.
Lou
I have a Remington 16" (107625-01)
The nib broke off of the block adjustment and it was bent anyway.
Where did you find item 26 and 27 above?
Thanks Daryl
Jan 29, 2010 | Remington Electric Chain Saw
Where can I get manual for model 358.355061 craftsman chainsaw ?
please tell us about the make(manufacturing company) of that machine,
Aug 07, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
