Question about Samsung Washing Machines
I just purchased a new top loading samsung washer, am wondering if the machine should make a mowning sound when it goes from one cicle to the other.
SOURCE: washing machine
thank you so much, I fixed it.
Posted on Apr 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Posted on Feb 28, 2009
dh1200s
  • 335 Answers
SOURCE: ERROR CODE dc keep coming up and machine don't complete the cicle
I have worked with a number of folks on FAV6800AW clutch issues and feel that your problem is related to the clutch. It could be an issue with the Tub Displacement Sensor but because you machine is terminating the spin cycle with a dc error I feel the TDS is working as designed but we can do a quick check. Take a look thru this post and see if you or someone you know has the basic mechanical skills to drop the clutch out of the machine and inspect the upper and lower clutch roller bearings and the clutch spring. If they are not rusted beyond clean up and the clutch spring is not broken you may get yourself back in service with little cost. Post back if you have further questions or need help in troubleshooting your dc errors. This is a quick test to see if the clutch is binding due to roller bearing friction; Lift your lid and with one finger can you rotate the wash basket CCW (counter clock wise) with very little force? I do it with my pinky.
When the clutch malfunctions due to dry or rusted roller bearing or a broken clutch spring the tumblers rotate slowly in spin cycle and toss the clothes around while the wash basket attempts to spin up. The load goes unbalanced, the wash tub starts making exaggerated excursions and the Tub Displacement Sensor signals the control board to try again to redistribute the wash load, I believe the process is 4 or 5 times. After the last try the control board terminates the spin cycle with a dc or UC error. Does this sound familiar? In spin cycle the tumblers will rotate maybe a half turn at the most at the start of the spin cycle and no more as the clutch engages the spinner shaft rotating the wash basket CCW. You do not fail with an empty wash basket because you are not tossing and clothes around while the wash basket is spinning up. You can redistribute the wash load till the cows come home and you will continue to fail with dc or UC errors to the display. Some folks have gotten their spin cycle to complete by loading the wash basket up with a load of wet towels, who wants to that. Read the post I refer you to and the links of folks that have done clutch maintenance or have replaced the clutch as in that post. To have the clutch replaced by a repair service would be in the ball park of $300+. You or someone you know can do this it’s just a tight work area. I will help you thru this if you decide to take on the maintenance.
Posted on Apr 17, 2009
Karthik316
  • 187 Answers
SOURCE: machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I need help to determine what Samsung plans to do to follow up on the current recall of specific samsung clothes washers, which could be subject to malfunction???
Important Information Concerning Your Top Load Washer
Consumers with a recalled washer will be offered two easy choices as part of the recall program.
  • The first option is a free in-home repair that includes reinforcement of the washer's top. Consumers who choose the in-home repair will receive a free one-year extension of the manufacturer's warranty, regardless of the age of their washer. The free in-home repair is not available for mid-control washer at this time.
  • The second choice is a rebate that can be applied towards the purchase of a new washer from Samsung or other brand washing machine, along with free installation of the new unit and removal of the old unit. The rebate amount is based on the manufacture date and model of the recalled washer. Consumers who choose a Samsung washer will receive an additional loyalty incentive up to $150 toward their new Samsung washer purchase.
Nov 09, 2016 | Samsung Washing Machines
My Samsung top load washer just stopped working it will not drain or spin
now plug it back in and see if it goes, sometimes that will reset it. if not, then time for a techician or new machine
Jul 14, 2015 | Samsung WF203ANW Front Load Washer
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
How do I remove the top of my washer machine to replace the spin cicle switch?
Cut and paste this video to show how to remove the cabinet.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
May 11, 2010 | Roper RAS6233KQ Top Load Washer
My washer machine model #2494230 elite only work
your machine need to hang out in better circles...only kidding...it sounds like your selector switch (timer switch) is defective and needs replacement.
Apr 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
