Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a starter for a craftsman 19 hp twin 42 " model
    Sergeant:
  • Craftsman Expert
  • 369 Answers
Search for your engine model number
Posted on Oct 17, 2014
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
defadad
  • 351 Answers
SOURCE: I have got a Craftsman model 917.270821 19.5 electric start 42" mower and cant get it to start I have replaced the starter and had the battery checked and all is good there, but dont seem to be gettin
check the wires from the back of the ignition and also the small wire that connects to the starter, if you get a 12v test light check each wire individually by holding the test light on the wire and have somebody turn the key, the test light should come on if the power is going through the wire.
If there is no power the ignition may need replacing
Posted on May 13, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
SOURCE: Need manual for craftsman LT1000 21hp v-twin 42
Go to craftsman website. They offer manuals, but you have to buy them.
Or; Look on ebay.
Posted on Aug 23, 2009
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
Need a diagram how to put a belt on a craftmans 42 inch 19 hp twin engine
http://media.fotki.com/1_p,srbkgqfsgggdwfgxgtqsskgwtqkq,th/rrdqddwqbxbwgwtsrdbxttqfksftw/1/1303472/5961991/image7270496268268023884img-th.jpg
May 26, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman 21 hp, 42" riding mower ~ 10 years old...when trying to start it, it just makes a loud metal noise like the gears are stripped. I'm going to try to remove the starter tonight...will I...
depends on the engine, briggs L-head opposed twins can be viewed by removing the sheet metal head cover near the starter, changing its starter is fun, as one of the bolts is under the flywheel, it can be changed without flywheel removal, with patience. Briggs Vanguard and Intek twins starters are easier to remove, the intek cowling has to be removed to see anything with starter in place but the starter can be removed with the cowling in place, the Vanguard has a few sheet metal covers that must be removed. If you've got a Kohler, starter removal is usually pretty straightforward, take the starter to a local repair shop for a comparison or test if you are unable to determine what's wrong. A decent shop will at least inspect it and show you what a known good starter drive looks like.
Jun 03, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Lawn tractor, engine model 42A707, starter spins but won't start engine; noted starter gear on top is worn down. Need help to either replace whole starter assembly with gear or just gear?
I had this same problem with a twin cylinder B & S engine and was able to get just the gear drive replaced without replacing the whole starter. Hope this helps you
Nov 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need manual for craftsman LT1000 21hp v-twin 42 inch
Or; Look on ebay.
Aug 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
Jul 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Turn key to run and nothing happens pops fuse
Those safety switches you mention above is a good first place to look. Possibly the magnetic switch that makes connection with the battery and the starter needs replaced. When you jumped the starter to turn the motor over did you have the key turned to ignition? No spark can come from a low oil shutdown switch located somewhere on the lower part of the engine (either low oil or bad switch), if the key was on. The switch can be bypassed to test its condition. Keep us posted.
Jul 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Let our Experts solve your startermoter proble
there 10mm bolts on each head behind the
breather cover and on back of cover and dip stick tube remove all then take off 11/4" nut remove fly wheel, then you can remove starter.
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Hi
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
88 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
