How do you enter the service door on Frigidaire Model FTF2140ES to observe leak. This is service area below the door.
    President:
  • 1,136 Answers
Hi, Remove the two screws in the lower front panel. Remove the panel and you will be anle to see any leaks.
Please let me knwo if I can assist you further.
Vic
Posted on Jun 20, 2009
My frigidaire dishwasher model #FFBD2403LW0B serial#TH13718959 leaks when it is running.seems to be leaking from underneath not from the front door.
how about putting the washer on some sort of stand so that you can look from underneath and then running it. use a light and observe where the leak is
Apr 11, 2017 | Frigidaire Dishwashers
My frigidaire front load ftf2140es washing machine washes through compete cycle but clothes still come out soaking wet
Onthe front panel there is a clean out pump cover I am willing to bet ther is $.53 in the pump and or 1 or 2 tooth picks blocking the pump!
Nov 06, 2016 | Frigidaire FTF2140ES Stacking Front Load...
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Water is filling up the bottom of the washing machine when the machine is off , it's a frigidaire model
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Check for tips on the link below to identify parts and removal:
Feb 07, 2013 | Frigidaire Washing Machines
Frigidaire FTF2140ES washer does not spin at any speed setting. Tumbles normally during wash and rinse. Pump operates and drains normally during the spin cycle, but drum remains still (no attempt to spin).
Usually on these models it is your door switch that is defective. There are two sets of contacts one too lock the door and the other gives contact for the spin cycle.
Jun 11, 2011 | Washing Machines
Mdl#FTF2140ES washer will not start, door lock light will not light up. Machine will not run diagnostic for codes. Used multimeter on door lock assem. it is fine.
Make sure the controls are not locked. There is a button that you will have to hold to unlock...it will have a padlock icon by it probably.
Kelly
Mar 22, 2011 | Frigidaire FTF2140FS Front Load Washer /...
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Leak
remove bottom panel 2 screw ckd pump and connecting hoses ckd drain hose in particular then have been known to crack
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Open Questions:
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
