Garbled sound with chromecast - Televison & Video
Setting up my iPad to use chromecast
what provider?
are you using their equipment ?
did the router or network name change or password?
Are you certain both chromecast and ipad are connecting to same network ?
chromecast only works on 2.4ghz networks
can you use your phone or another device
sounds like cast is trying to connect to old network and ipad is on new network
Nov 10, 2016 | Apple iPad Tablets & eReaders
Toshiba theater wide HD external speakers not working?
When you convert from HDMI to DVI you only convert the video signal so you wont get any sound. To get the sound you will need a device that extracts the sound from the HDMI signal. These are readily available. However as you need the Chromecast to plug into the DVI converter and the sound extractor, you will also need an HDMI device that converts a single HDMI input the two HDMI outputs, or a sound extracting device that has an HDMI pass through. Ether way this is going to be a bit expensive compared to the original cost of the Chromecast. It might just be cheaper to buy a TV that has an HMDI input.
Jun 21, 2016 | Toshiba Televison & Video
Can Chromecast damage TV? I recently bought a Chromecast and it worked fine. Then the picture disappeared, but I still had sound. Today I reconnected it to test it, and one hour later I have no sound
It won't damage the TV. Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box at the display window, and press enter to get all related posts. It will make surf easy.
Jan 24, 2015 | Samsung Televison & Video
How do i stream content video and more Using my Google chrome cast HDMI dongle to my TV LED or LCD
You have to purchase a chromecast compatible app from the app store in order to strem your own video, however some services offer chromecast in the app such as YouTube, Netflix, Pandora, and others. To get chromecast to work with your phone you need the chromecast app
(Free Download) https://play.google.com/store/apps/details?id=com.google.android.apps.chromecast.app
Search Chromecast in the app store to see a list of available apps.
Once you have a compatible app, setup your chromecast by plugging it into your TV. (Both the key itself, and the USB power cable) change your TV input to the input you plugged your chromecast's key into. Make note of the name it gives your chromecast. Once connected to your WiFi and setup, open the chromecast app on your phone or device. It should pop up and ask you to connect to your chromecast. Once connected open a compatible app and click the chromecast streamer. It looks like a rectangle with a WiFi symbol in the lower left corner. Your TV should now show the main page for your app! Whala!
Have fun streaming using your Chromecast!
- Daniel -
Apr 16, 2014 | Samsung i9500 Galaxy S4 32GB Unlocked...
How to connect chromecast
Sounds like the Desktop has a problem withe the adapter.
If you have an icon by the clock, right click on it and go to network connections or sharing center to view you adapter setting.
If you get this far get back with me.
i think a statc IP address has been entered by malware.
Apr 01, 2014 | Computers & Internet
My chrome cast screen is stuck showing the 100% sign with a circle moving around it
Sounds like it got stuck doing an update. Cycle the power on the chromecast. Unplug the chromecast and re plug it in.
Mar 09, 2014 | Google Chromecast
Garbled sound as the system accesses something. Disk light pops up at same frequency as garbled sound appears. The Windows startup and shut down sound also is garbled. Using Windows XP on an ASUS K8V...
1. check the cable to the DVD or CD to the sound card it may not be connected properly.
2. remove the sound card from the motherboard and do "shutdown" then restart without the sound card.
3. Shutdown again reinstall the sound card and reinstall the drivers for the sound card.
4. check the the manufacturer website for any firmware upgrade drivers
Sep 21, 2009 | ASUS Computers & Internet
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
