Question about Craftsman 25cc Gas Line Trimmer
Two ports on Walbro carb - which line hooks to which?
Many comments on the fuel line hook-up - but I need to know which line hooks to the two ports on the carb itself. On from the tank and one from the primer bulb - please tell me which hooks where on the carb??? This is such a great site for a resource. Thanks for the professional advice!!!!
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with
Let me know if you need further assistance.
Jim
Posted on Jun 20, 2009
  • Jim Parker
    Jim Parker Jun 23, 2009
    Did this solve the problem?
    Jim
Walbro carburetor diagrams
must be a small tiller to have a walbro carb on it most of these have a hole drilled in throttle cam ("D" looking thing on top) that the cable has a "L " hook that goes into it cable clamp must me loosed to allow a 45 degree entry of "L" hook into "D" plate
Jul 23, 2014 | Craftsman Garden
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Ryobi 410 mini tiller w/Walbro WT149A primer bulb won't prime. New bulb, new fuel lines, hooked up right, carb cleaned. Been sitting for several years.Runs when fuel is pumped into the fuel inlet.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 21, 2012 | Garden
Fuel lines rotted off of my McCulloch 4600 chain saw
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope this helps!
May 18, 2010 | McCulloch Garden
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Which lines hook to what?
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Aug 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Fuel lines rotted replaced them. carburation is off how do i reajust the carburator it has two small ajustments side by side and one large ajustment above it i think the one large one is the idle screw i...
large adjustment is the idle
if it is a zama carb then 1 turn out each
if it is a walbro carb. 1and1/4 out each
preliminary adjstments they will have to be tweeked after its running or maybe not
Jun 10, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
2,255 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
