Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water inlet valve
I'm replacing the water inlet valve! I'm trying to remove the cracked one & was curious to know if it should be hard to pull off after the screws are removed? I don't want to break anything
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool GHW9100LW2/CSR1903623 flashes a FH code
The "FH" error can have several causes, so this can sometimes be a tricky problem to diagnose. Some of these error codes can also be erroneous. The first step to troubleshooting your problem should be to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer (or brain) of the washer. Sometimes this is all it takes to correct minor glitches. If your error code reappears following a reset, then you know you have a genuine problem. If the "FH" error persists, the following link explains what to do:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Although, you may be correct in your assumption of a possible water inlet valve problem, I would recommend you read through the link provided and try to eliminate the easy things first. Check your installation for a possible siphoning issue, followed by a check of the drain pump. If those items check good, check the sediment screens in the water inlet valve. If you live in an area that has hard water, or if you use well water, the sediment screens can become clogged with deposits and debris. If you suspect a clogged inlet valve you can also remove it and thoroughly clean it in a 50/50 solution of water and distilled vinegar. Allow the inlet valve to soak in the solution for about half an hour and flush real well with clean water. Avoid submerging the solenoids and electrical connections, or getting them wet.
If you have questions along the way, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
  • 3230 Answers
SOURCE: HF error code
hi,
check this-
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
good luck
Posted on Mar 28, 2009
quatlew
  • 139 Answers
SOURCE: Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Posted on Mar 15, 2010
  • 41 Answers
SOURCE: Hi, I have a whirlpool AWO/R4205 that will not
all washing machine perform a drain cycle before any wash - that's just the norm geoff.
I'm assuming you'll be getting an F1 fault code
Sounds like the inlet solenoids have gone. get your multi meter on the solenoids - the readings should be around 3.4kOhms - 4.4kOhms
If this proves ok then you'll need to do a 'live test' on the power going to the solenoids at the start of the cycle. (Take all precautions so as not to give yourself a shock) you'll expect a reading of 180-230v
If the resistance across the solenoids are between the given values and you're getting power to them then the fault lies with the water supply.
If there is no power going to the solenoids at the start of a programme then you need to check wiring back to the CCU for continuity. If the continuity proves ok then you'll need to replace the programme timer mate
Posted on Jun 12, 2010
Not getting water to ice maker
Directions for testing an icemaker water inlet valve.
Before you begin to test your icemaker's water inlet valve, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this test.
  1. Locate your icemaker's water inlet valve, it is typically located behind a refrigerator. Gently pull your refrigerator away from the wall. You may want to place scraps of carpet, of some other soft material below the fridge to prevent damage to the floor. Turn of the water valve's water supply by closing the shut-off valve in the waterline leading to the water valve. Remove the lower access panel on the back of the refrigerator using a screwdriver or a nut driver.
  2. Place a container under the valve to catch any water that may spill from the water valve and its fill tube. Remove the water valve's fill tubing. Loosen the flare nut on the brass fitting that is found on the inlet side of the water valve. You can use a wrench to loosen the flare nut.
  3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nutdriver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
  4. There are two wires connecting to the terminals of your water inlet valve. If yours is a double solenoid water valve, it will have four wires. Be sure to label each wire so that you know where to reconnect them later. Firmly grasp the metal connector of the wires in order to remove the wires. You may need to use a pair of needle-nosed pliers. Do not pull on the wires themselves.
  5. Set your multitester to the R X 1 ohms setting to test for continuity. Place each of the multitester's leads on a terminal. Your multitester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
  6. If the test you conduct with your icemaker water inlet valve does not produce these results, then you should replace the component.
Oct 12, 2012 | GE WR57X10033 GE Refrigerator Water Valve
The ice maker isn't working
Hello there,
You should first try to see if water is getting into the ice maker that is to be used to make ice. That is controlled by the water inlet vale. Also check if the tube that passes water into the ice maker is not clogged with dirt.
You need to run a check on your water inlet valve and the defrost thermostat.
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer. An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned. Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it. .Before you begin to test your icemaker's water inlet valve, make sure you disconnect the appliance's power supply.
  3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nut driver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
  5. Set your multi-tester to the R X 1 ohms setting to test for continuity. Place each of the multi-tester's leads on a terminal. Your multi-tester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
To test you defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat To replace it: http://www.fixya.com/support/r10513650-replace_defrost_thermostat
If both have been tested and you found out the problem is not from either of them, then i will advice you replace the ice maker mechanism.
Hope this helped. All the best Elect_Comp
Sep 27, 2011 | Kenmore Side by Side Refrigerator
Our ice maker just stopped making ice. we have replaced the filter and reset it and don't know what else to do
Hello there,
Sep 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Kitchenaid superba- The icemaker will not fill
Hi. This will more than likely be an inlet issue.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Nov 13, 2009 | KitchenAid Refrigerators
Internal water dispenser not working ...already tried changing filter.
HI, the water inlet valve should be inspected for damage, or clogs at this time . This will be the culprit.(check for frozen lines as well)
Nov 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can get water from the main water line but can't get water up to the ice maker help
HI. The inlet valve is suspect in this case. I recommend to inspect this device for damage. replace if necessary.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
NOTE:- Make sure the inside line is not frozen over before preforming the inspection of the inlet valve.
Oct 19, 2009 | Frigidaire Freezer Refrigeration White...
Water dispenser and ice dispenser not working
OK, i would start by checking the lines to see if they are frozen over. if the lines are OK, move on to the inlet valve.
Ok, if the valve test is negetive, the culprit will be the dispenser board itself. have it replaced asap, if possible.
Sep 19, 2009 | Refrigerators
My ice maker is not making ice. Where do I start the trouble shoot?
The likely culprit will be a damaged inlet assembly
Sep 07, 2009 | Refrigerators
No water or ice
HI. could be4 as simple as a frozen inlet line or, the water inlet assembly valve may be damaged as well. I recommend inspecting the lines for ice or frozen water. if the line are Ok and not frozen, this will confrim a defective inlet valve.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Aug 17, 2009 | Refrigerators
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
12 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
