Question about Dometic Heating & Cooling
Dometic comfort control 5 button won't shut off a/c automatically
    Genius:
  • Dometic Master
  • 1,363 Answers
Indoor sensor issue.
Posted on Aug 16, 2015
5 Suggested Answers
SOURCE: RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Posted on Mar 18, 2009
motor1258
  • 6674 Answers
SOURCE: problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
Posted on Aug 07, 2009
hvac1960
  • 2133 Answers
SOURCE: WHAT DOES EE MEAN ON A DOMETIC COMFORT CONTROL
EE- High Pressure problem.
Posted on Jan 02, 2011
SOURCE: Duo-Therm Comfort Control Buttons Not Responding
Take your control apart to expose the buttons. The buttons are secured by small clips that can be removed by usimng a cross tipped screwdriver. When removing the buttons be care not to lose the small springs under the buttons. Once removed spray the contacts with contact cleaner and reinstall everything. I had the same problem and after performing this procedure the unit worked much better. Hope this helps.
Posted on Jul 30, 2013
Error code E2
open circuit or out of range indoor temperture sensor. locks out cool and heat.
Aug 09, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
New thermastat Air won.t turn on at all or if it does it only stays on for a second and then goes off and won't come back on.
What model is the hvac unit that it is hooked to? There is a high possibility that the wires are not hooked up right. You should check the connections at the hvac and see if they are color coded and wired right.
Jun 22, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Furnace intermittent on Comfort Control
It depends on what mode the unit is in when your looking at the screen. No call, no display. No errors, no display
Apr 11, 2014 | Dometic Heating & Cooling
Blank screen no numbers
se if you have 12 volts dc available might be a fuse.
Feb 06, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Flashing code ee
sounds like defective t-stat or it needs to have time and setpoints reconfigured
Sep 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
No display
takes 12 volts d.c to work.
Jun 16, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Problem w/ dometic penguin a/c. upgrade kit?
Aug 07, 2009 | Dometic Rooftop RV Air Conditioner
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
