Question about Bernina Virtuosa 150
Feed dogs are to low to move fabric. the button on the right side is supposed to raise & lower them I think but it does nothing. Any ideas? thanks!
  • 202 Answers
Your machine needs servicing. The feeddog mechanism is stuck most likely from lint or dirt in it. Pop off the needle plate and clean good there and inside the door to the bobbincase area. The mechanism is inside that door to the right an inch or so. Covers have to be removed to clean this properly. The height adjustment is inside in that same area also. Time for servicing.
Hope the top just needs a good cleaning. Good luck.
Posted on Aug 29, 2009
I have a brother ls 2020 and it will not feed fabric through. I am thinking my feed dogs are messed up but i don't see anything about lowering or raising them. Will I have to take it apart?
According to the manual, your machine does not have the capability to drop/raise the feed dogs. Instead, there is a cover plate that is installed over the feed dogs when performing darning or free motion quilting.
Check that your stitch length is set high enough to actually move the fabric. Some machines also have a presser foot pressure adjustment that will increase or decrease the amount of pressure the presser foot applies to the fabric and the feed dogs. If your machine has this adjustment, it may help to increase the pressure so the fabric will move better. Another thing to check is whether you are using the correct presser foot that will actually rest on the feed dogs.
Reading the hints on pages 28 and 29 may be helpful.
User Guide Manuals LS 2020 Others Brother
Another possibility is that the feed dog points have been worn off. When the points are worn, they no longer grip the fabric like when new. When stitching, be sure to never run the machine with the presser foot setting directly on the feed dogs, it without fabric.
Jan 05, 2018 | Brother Sewing Machines
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
I have a Necchi 537FA and I want to know what the knob (on the right hand side) with the dot and knit symbol does. This knob is the last one on the right hand side. Thanks in advance for the help.
I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
Aug 19, 2015 | Necchi Sewing Machines
The piece that moves the fabric is down ( as nedded for embroidery) it should be up for conventional sewing, please help me.
look in the operation manual for the feed dog lever and push it to the up position so the feed dogs will come up..
Jun 06, 2015 | Sewing Machines
The stitching is stuck on 0 length
The first thing to do is make sure the feed dogs are supposed to be feeding the fabric through. Check the lever or button that raises and lowers the feed dogs. Make sure it is in the position for ordinary sewing. If it is not, then move it to the correct position. Then, without any fabric under the presser foot, turn the main shaft of the machine by hand and watch the feed dogs underneath the presser foot. Don't simply look down at the dogs. Lower your viewpoint so that you're looking from front to back just SLIGHTLY above the horizontal level of the sewing deck. While looking at the area right where the feed dogs are, watch to see if the dogs a rising SLIGHTLY above the level of the deck. If they aren't, and if the feed dog lever is in the correct position for ordinary sewing, then something is out of adjustment or is broken. If you are not mechanically inclined or if you are totally terrified of opening up your machine to take a look, you'd better take it to a shop and let them do it.
Apr 03, 2015 | Sewing Machines
The needle moves up and down and the presser foot is lowered (and attached properly) but the fabric is not being pulled through.
Yes, there definitely could be something wrong, but there are some things you should check. Most machines are capable of raising and lowering the feed dogs; yours might be fully or partially lowered, so that while it moves, it's not far enough up to the surface to move the fabric. Using the lever or dial, LOWER it all the way, then RAISE it all the way, but you're not finished. It will still not raise until you turn the hand wheel TOWARDS you (ALWAYS towards you on every machine) at least one and possibly two revolutions. You'll then SEE and most likely HEAR it click up. I know someone who got a steal on a Brother marked defective because the feed dogs wouldn't raise, so she brought it home, turned the hand wheel two revolutions, and viola! The feed dogs raised!
Dec 03, 2013 | Singer 5050 Mechanical Sewing Machine
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Fabric Won't Move
I don't have this machine, but any machine I've had that you can lower or raise the feed dogs had the switch in the bobbin area. Mine is on the right side when you flip down the little door. It moves up and down to move the feed dogs. good luck
Dec 29, 2008 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
209 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
