Question about Delta & Single Handle Shower Faucet
Instal 58572 replacement part - Delta & Single Handle Shower Faucet
HD REPLACEMENT
Check if you can use SATA else you'll have to look for IDE
Actually to insert a SATA drive is easier then replace a light-bulc.
Just remove cables, unscrew from "drawer" insrtn new drive, scress, replace cables.
If it's a system disk, the difficulty is resintall your system. After you've replaced Hard disk, formulate your question with more doubts
See some fine videos here
How to install SATA hard drive into computer
How To Install Internal Sata Hard Drive and Activate In Windows OS
How to install and remove SATA Hard Drive
How to Replace Desktop Hard Drive
How to Install Second SATA Hard Drive
Jun 27, 2015 | Computers & Internet
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
Heater core leaking through floor vents.
Bad heater core you will need to replace it. About a 2 hour job, very easy to do:
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the HVAC filter cover.
Remove the heater core/evaporator tube seals from the module.
Remove the heater core cover screws (1).
Remove the heater core retaining screws (1).
Remove the heater core retaining straps.
Remove the heater core.
Remove the rubber seals from the inlet/outlet pipes of the heater core.
Installation Procedure
Install rubber seals to the outlet/inlet pipes of the heater core.
Install the heater core to the module.
Install the heater core retaining straps.
Install the heater core retaining screws (1).
Install the heater core cover.
Install the heater core cover screws (1).
Install the heater core/evaporator tube seal from the module.
Install the HVAC filter cover.
Install the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
May 19, 2011 | Cadillac DeVille Cars & Trucks
How to replace power steering pump impala 2000,engine 3.4
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt from the power steering pump pulley. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
5. Remove the power steering pressure line from the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L)
6. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Remove the power steering pump mounting bolts from the power steering pump.
8. Remove the power steering pump assembly.
9. Remove the power steering pump pulley from the power steering pump. Refer to Power Steering Pulley Replacement.
10. Remove the power steering pump reservoir from the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
1. Install the power steering pump reservoir to the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
2. Install the power steering pump pulley to the power steering pump. Refer to Power Steering Pulley Replacement.
3. Position the power steering pump assembly to the engine. Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts. Tighten the power steering pump mounting bolts to 34 Nm (25 ft. lbs.).
5. Install the power steering pressure line to the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L).
6. Install the power steering return hose to the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
8. Lower the vehicle.
9. Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L
10. Fill the power steering system. Refer to Refilling the Power Steering System.
11. Bleed the power steering system. Refer to Bleeding the Power Steering System.
12. Inspect the power steering system for leaks. Refer to Steering and Suspension Leaks.
13. Remove the drain pan from under the vehicle.
You may want to take it to the dealer or other repair shop. It is very difficult and will consume a major portion of your day.
Nov 28, 2010 | Car Audio & Video
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Nov 18, 2010 | 2001 Pontiac Aztek
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
How to remove heater core from 2000 Pontiac Montana. Antifreeze leaking on floor.
Wow I hope youre mechanicly inclined, big job the entire dash & carrier have to come out 7-15 hr job if you know what you are doing to much to list hear I would check heater hoses at fire wall first make sure they arnt leaking. I wish you well
Aug 31, 2009 | Pontiac Montana Cars & Trucks
Rear axle bearing replacement
REAR WHEEL BEARING/ HUB
Removal Procedure
  1. Raise the vehicle. Refer to Vehicle Lifting in General Diagnosis.
  2. Remove the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
    1. Remove and support the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Brakes.
    2. Remove the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Remove the ABS sensor wire connector.
    4. Remove the four bolts from the control arm.
    5. Remove the hub and bearing from the control arm.
    6. Remove the brake shield from the control arm.
    7. Clean the control arm face and the bore before installing the hub and the bearing.
    1. Install the brake shield and the hub and the bearing to the control arm with the four bolts. Be careful not to drop the hub and the bearing, as it could be damaged. Reconnect the ABS sensor. Tighten the hub and bearing bolts to 70 Nm (52 ft. lbs.).
    2. Install the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Install the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Disc Brakes.
    4. Install the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment. Tighten the wheel nuts to 140 Nm (100 ft. lbs.).
    5. Lower the vehicle.
Feb 14, 2009 | 2002 Pontiac Bonneville
Delta & Single Handle Shower Faucet  Logo
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
