Question about DeLonghi Pinguino PAC-210 Air Conditioner
Never has got cold or hear a condenser
I have had this 2 summers it nevever gets cold air
Why is there condensation?
Moisture laden air will always condense on a cold object - like the moisture that collects on your glass of ice tea during the summer.
Jul 19, 2015 | Refrigerators
Why in the summer dose one of my AC vent in the celling have so much condensation that it leaks through the celling
It is ICING UP and getting so cold the humid air around the unit is condensing back into water. Check the lines and make certain they are INSULATED (covered) properly. Check drip trays and other lines for leaks and/or clogged exits.
Jun 28, 2014 | Heating & Cooling
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
I have 2 of the MSZ-A09NA Mr. Slim model in my 400 sq. ft. cottage. In the summer time my cottage is always damp feeling and the ducts drip condensation. How do I prevent this dripping?
It sounds like you have too much air conditioner vs. conditioned space. This would cause dripping and short run times. Air conditioners are designed not only to cool the house but to pull the moisture out, if it is too big and cools the area too fast the outside of the ducts will begin to collect condensation like the outside of a cold glass of water.
May 04, 2011 | Mitsubishi MS09TW Air Conditioner
There seams to be water coming out from underneath the fridge, especially in the summer. I have just re-newed the seal but still find there is a pool of water coming from underneath. Can you shed some...
Hi Lyn, It is most likely condensation from humid air condensing on your coolant line, the one that carries the cooled refrigerant from the condenser. This fits with your description of it being worse in summer, when the air has a higher level of humidity. Your best bet is to put a shallow tray under your fridge to catch the water. Alternatively, pull the fridge out and feel the lines when it's running. When you find the one that is very cold, see if you can wrap it to insulate it so that moisture in the air does not condense on it.
Feb 19, 2011 | Refrigerators
We have a Rheem air conditioner that is 9 years old Model number RAKA 037-JAZ and have been having some issue with it. Last summer the condenser wasn't coming on so we have a friend who is a HVAC guy and...
It sounds like he got you a Hard Start Kit/Capacitor, that might explain
the five minute delay. When the fan is not operating the compressor will
make a loud noise..
Check to make sure insulated suction line is cold, that mgiht tell you that the compressor is working.
Check to make sure hot air is discharging out of the condensor.
If neither of these to things are happening and you think the compressor is on, it is possible that you are low on refrigerant.
Check to make sure your indoor blower is working, the filter is clean and check to see if you have condensation dripping from the indoor unit
Jul 11, 2010 | Heating & Cooling
I have two frigidaire a/c's. 1 is not cold enough
If the compressor's running and you're not getting cold air, then, you're low on refrigerant meaning you have a leak in unit,or a dirty condenser.
Aug 18, 2009 | Heating & Cooling
Unit is cold but fan not working. had the condenser (i think) replaced two summers ago. if its the condenser, can i fix it myself
its not the problem of condensor. the fan motor have a capacitor connected to it just replace it and bring a little bit powerful than it.. this is a rare case............have a nice day :-)
Jun 15, 2009 | Heating & Cooling
Lg minisplit heat pump will not heat
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Feb 26, 2009 | Heating & Cooling
Defrost Cycle Problems
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
DeLonghi Pinguino PAC-210 Air Conditioner Logo
29 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
