Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
How to reset the replacement lamp meter on an hitachi 55
Hitachi 55vs69A TV TEMP and LAMP red lights blinking. Can I solve this problem myself or do I need a TV repairman?
If you replace the lamp and reset the lamp timer then that will do it.
For resetting of the timer, see instructions within the lamp box.
Hope that helps.
Nov 13, 2010 | Hitachi 55VS69 55" Projection HDTV
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
How do I know which replacement lamp light to get for my hitachi ultravision 50 in tv. We can't find the manual. Is there any other way to be sure we get the right one?
If you are able to remove the lamp that needs replacing you will be able to take it to Hitachi's authorised repair agent and they can order one for you. But in saying that the Hitachi authorised repair agent will know what lamp to replace it with. I hope this helps.
Dec 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Keeps cutting off
If you haven't replaced it the first suspect is the lamp. I have included a link so you can purchase the lamp if needed. Please take a moment to rate my answer. thank you.
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX21516/New.aspx?ModelMfgName=Hitachi+Ltd&ModelBrandName=Hitachi&ModelNumber=55VG825
Nov 19, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Replaced a lamp and unable to turn on television, lamp light flashes
this works. remove lamp and place in your freezer for 5 minutes. reinstall. when unit comes on, go to menu and find lamp setting. reset lamp to zero hours. the unit still thinks it has old lamp
Nov 11, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
The red lights are on for the lamp and temp
Replace the lamp. Look in your manual and find the number for your lamp. Do a search on line, buy the original hitachi replacement. They last longer. Hope this is helpful
Nov 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I've replaced the bulb in my 55vs69a Hitachi and now it is not as bright as before. How common is it for a new bulb to be bad? Additionally, is there anything I can do short of replacing that bulb or...
It is always possible to get a bad lamp. Especially if it was not a Hitachi lamp assy.
If the replacement lamp was a generic, I would not trust it. Most all cases with a dim picture or dimmer picture after replacing the lamp have been the lamp it's self. Rarely have I seen the Ballast cause it.
Hope this helps,
Skyassoc
Jun 24, 2009 | Hitachi 55VS69 55" Projection HDTV
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
Mar 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision digital
Good Day, mmurray1959;
To me it sounds like you to replace the lamp if you want to view your TV in the future. Good Luck, big IRISH. PS most lamps last about 5,000 hours.
Aug 18, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
