Question about Honeywell Heating & Cooling
Forgot to mark wires in old thermostat - Honeywell Heating & Cooling
4 Suggested Answers
SOURCE: Forgot to mark wires before removing old thermostat...
You can take a look at the blower unit where the wires from the thermostat connect to. Usually they're labeled on the circut diagram on the front panel, or on the board itself.
This site may also be of some assistance.
http://highperformancehvac.com/thermostat-wiring-colors.html
Posted on Oct 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Three wires not marked for new Thermostat!
You will need to go to the heating system and see what color wires are hooked to that. Typically the black and white wires will be used unless they used another color due to a bad wire. Hook the colored wires to the R or RH terminal on the thermostat and the other wire to the W terminal. You can also try taking the wires you have and one by one twisting them together and have a second person inform you when the heating system turns on. Take those two wires and hook them to the terminals I mentioned above.
Posted on Jan 14, 2010
  • 1015 Answers
SOURCE: How to identify what wires go to each terminal on
Depending on what thermostat you have and existing wires. Typically red and white are for heat and yellow and green are for cooling. On base of thermostat there should be initials stamped to identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most uses you need to jumper these two together. You may have a blue wire instead of yellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Posted on Dec 04, 2010
HOW DO REWIRE A NEW THERMOSTAT INTO A LEC FRIDGE R5026W
if there are only 2 wires it wont matter
Feb 01, 2015 | Microwave Ovens
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
I already sent this once but not certain it went throughSears Electric Whirlpool dryer LEB6000PO1 ( or P01) high thermostat.
If that is an OEM part you SHOULD NOT have to cut or change anything!! What is the model of the machine? What is the part number of the new and old parts. IF YOU CAN EDIT YOUR POST, remove the personal information
Jul 21, 2013 | Dryers
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I Have a Kenmore dryer and i am replacing the hi-limit thermostat but my new thermostat does not have any markings on it to tell which wire goes to what terminal. Does it matter? I marked the wires as I...
No, it doesn't matter. But the wires should have a "memory" and a length which would indicate which wire plugs onto which terminal on the thermostat.
Charlie
Feb 12, 2011 | Kenmore 500 6952 Dryer
Jan 14, 2010 | Honeywell Programmable Thermostat Heater
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Oct 18, 2009 | Honeywell Electronic Programmable...
Aug 27, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
