Question about Chapin Compression Sprayer Repair Kit 6 4627
Repair Chaplin industrial sprayer with kit 6-4627
Model 030XPEG. Why won't sprayer pressurize?
Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden
www.amazon.com > ... > Sprayers
Amazon.com, Inc.Amazon.com : Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden ... Kit with Extension Wand and Adjustable Nozzle(Only for models 1991A, 1992A, .
Oct 08, 2015 | Gilmour Garden
Is there someplace to buy a whole rubber washer repair/rebuild kit for a Roundup 4gal BP sprayer? It's square and was built in 2005 unlike the rounded newer ones. thx joe
I've found buying one thats too big and cutting it to size and shape works best on my sprayer. You could go for a sheet of rubber and cut it all out with an exacto knife too.
May 13, 2014 | Roundup Garden
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
I was spaying and pumping up the pressure, when pump went slack. I would try and pump it up , but spray would just dribbvle out and was weak in pressure
Hi and welcome to Fix Ya, I am Kelly.
One of the seals has failed in the pump. i.e cut o-ring or a leather rolled out of place.
Go to this link.. http://www.chapinmfg.com/PartsAccessories.asp
Find your model number and on the far right of the page is the repair kit for your sprayer.
This is the 6-6180 repair kit:
http://www.chapinmfg.com/ShowParts.asp?PartNum=6-8180
This is the 6-1925 repair kit:
http://www.chapinmfg.com/ShowParts.asp?PartNum=6-1925
The repair kits above are examples only... find the kit that is for your sprayer and order it.
Once you find and replace the damaged seal it will work fine.
Thanks for choosing FixYa,
Kelly
May 16, 2011 | Chapin Garden
I e-mailed a question on a Chapin Hand Sprayer #1949 5 days ago and have not heard from anyone. Don
Welcome to FixYa!
"I have a Chapin Hand sprayer #1949 3 1/2 gal. I need to know how to get the pump apart to install a Industrial repair Kit #6-4627."
TO UNLOCK PUMP:
Turn handle counterclockwise until 3-prong clamp is loose.
Then rotate clamp counterclockwise to stop and lift out.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 23, 2011 | Chapin Garden
I have a chaplin SureSpray, and it was given to me. On the bottle it says it is for pest control, fertilization, and weed control. It is a 1 gallon sprayer. The model # is20000#20010. 1G/3.8L. I just need...
Push the handle all the way down turn it counter clockwise and unscrew the pump handle and lid open it up put in your product and install if reverse order then Pump it to spray. Hope this helps if you need more help let me know. also sometimes they stick in this case run hot water over the cap area.
Dec 16, 2010 | Chapin 2001 Rb2000 Poly Sprayer 1 Gal
I have a 2 gal ortho heavy duty pump sprayer and I'm need a new nozzel. Where can I find replacement parts?
I guess a company called the Fountainhead Group makes a lot of different sprayers other companies. They have repair parts available on their site. I replaced the nozzle and installed fresh gaskets with a kit from Lowes and with info from this site; http://www.creativeworksforchildren.com/how-to-repair-ortho-roundup-garden-pump-sprayer.htm
Aug 03, 2010 | Garden
Where do i find parts for a RoundupĀ® Branded Tank Sprayer System.
Hi.
roundup branded tank parts/repair kits can be found here Amazon com roundup sprayer parts Just click on the link and choose one (which fits our budget, model etc...)
I hope this was helpful.
enjoy
Apr 18, 2009 | Garden
Chapin Compression Sprayer Repair Kit 6 4627 Logo
289 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
