Question about Whirlpool Duet GHW9150P Front Load Washer
Belt on whirlpool duet washer ghw9100lw1
How do you get the belt on. We got a new pulley and belt. the belt seam short but the right part. how do you get it back on.
  • 999 Answers
This can be a finger buster. I put it on the motor pulley and roll it onto the tub pulley. I have seen others use a large crowbar to slide it over the motor pulley last but that seem risky to me. It is a very tight fit.
Eric
Posted on Jun 20, 2009
Age of Whirlpool Duet Serial Number CSP 2807389?
Age of whirlpool duet washer/dryer with sn csr2213663 model either ghw9250mt2 or gew9200lt1
Jan 31, 2014 | Whirlpool Washing Machines
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to replace my barrens in my washer tub. ghw9100lw1
You better looking for a new washer. The cost for bearing about over 400 dollars.
New washer about $750.00 model 9550W at Sears or Sears outlet.
Good luck
Jun 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you replace the drive belt on the whirlpool DUET
The following link explains step-by-step how to replace the drive belt on a Whirlpool Duet washer:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is a very simple procedure, but if you experience any difficulties, please post back and let me know. I hope this helps you.
Nov 27, 2009 | Dishwashers
I need help on how to install a drive belt for a ghw9100lw Duet Front loading washer. The belt seem too short but the part guy said this is the right belt. Any tricks to getting this thing on? Help! Thank...
The following link explains how to install a drive belt on a Whirlpool Duet front loading washer:
I know the belt seems to be too short, but it is supposed to fit tight. There is no tensioner that you can loosen, either. This is a simple design that uses the tight fit of the belt to keep it from coming off the drum pulley. It will go on, but it may require some effort. If you have any questions, please let me know. I hope this helps you.
Oct 16, 2009 | Washing Machines
How to replace the belt on a whirlpool duet washer
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Feb 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
149 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
