Question about Cub Cadet Garden
Zero turn mower will not go forward or backward
Cub cadet zero force s 48 in cut
    Welcome Back:
    Visited the website for 2 consecutive days.
Check that the transmission tensioner spring is still connected. If it breaks you won't move, much cheaper and easier to fix than transmission (center rear of are)
Posted on May 01, 2018
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Pump has burned out
Posted on Dec 17, 2014
5 Suggested Answers
  • 109 Answers
SOURCE: I have a cub cadet Zero turn mower Z50 and when I
On the transmissions, there are bypass levers...make sure they are pushed in and not pulled out
Posted on Jun 13, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
woobie dog
  • 1273 Answers
SOURCE: Zero turn cub cadet Zero Force 50" cut stopped running while mowi
I have an idea. Try to start it again. It should start right up. When it dies again, immediately crack the fuel filler cap, and listen for a vacuum. If you detect a vacuum, clean the cap well, and pay particular attention to the vent hole on the cap. If it is plugged, it will do just what you were seeing.
Hope that this helps!.
Best Regards,
--W/D--
Posted on Aug 24, 2009
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Posted on Jun 21, 2010
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Apr 18, 2009 | Briggs & Stratton Garden
Garden Logo
359 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
