Question about SI-TEX Boating
Lowrance 1220 flasher can the light be changed by me ?
How to change language to enlish
Hi Kane,
I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf
Apr 25, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
No brake lights or emergency flashers. Changed
Try adjusting the brake light switch on the brake pedal.
The flashers have a relay in the circuit, test it and see what you get . The flasher switch may be the culprit also. By pass the switch with a pair of jumper wires and see if flashers work.
Apr 24, 2010 | 1991 Jeep Cherokee Briarwood
Unit turns on by itself
I have two Lowrance X 125 that I don't get any Power to.
Feb 07, 2010 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance Endura-projections other than Lat/Long?
Yes, if you download the newest firmware upgrade version 1.2 it will add in other projections and datums, as well as fix other known issues. I would recommend that you run both the 1.1 and 1.2 upgrade for your Sierra, the 1.1 upgrade will fix some issues with the base map.
Both upgrades can be found at the following location: http://www.lowrance.com/en/Endura/More/
I hope this helps.
Dec 09, 2009 | Lowrance GPS
Hazard flashers do not work. Turn signals do. Changed relay. Nothing. Ugh. 1992 oldsmobile cutlass supreme
You changed the hazard flasher or the turn signal flasher? It has two, one for the hazard and one for the turn signals
Aug 31, 2009 | 1992 Oldsmobile Cutlass Supreme
Turning Lights Not Working
If you put a 2 element bulb in a single bulb elemet socket you would or could destroy the flasher unit. Especially if it is a electronic flasher try replaceing the flasher but get mechanicl flasher they last longer.
Jul 09, 2009 | 1998 Toyota Sienna
How do I convert the gps coordinates from Google Earth?
In GoogleEarth, change your coordinates to decimal format. In your Lowrance GPS, change that format to decimal. You don't mention which Lowrance model so I can't find the online manual to tell you exactly how to do it.
Jan 01, 2009 | Garmin eTrex Legend GPS Receiver
Boating Logo
41 people viewed this question
Top SI-TEX Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a SI-TEX Boating Expert? Answer questions, earn points and help others
