Question about Brother HL-5370DW Duplex Wireless Laser Printer
Vertical black line when I print - Brother HL-5370DW Duplex Wireless Laser Printer
    Champion:
  • 411 Answers
Try with a new cartridge (that includes a new drum)
otherwise
replace drum
or fuser.
Posted on Aug 05, 2014
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Prints vertical lines crooked
You should be able to go into the print driver settings and do a print head alignment.
That should cure the problem.
Jan 15, 2018 | HP PSC 500 All-In-One Printer
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
2 vertical, parallel, black, lines print on copy
Sounds like it could be bad cartridge or scanner. Try replacing cartridge first cause this is pretty easy to do and is alot cheaper.
Feb 11, 2009 | HP Office Equipment & Supplies
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Brother HL-5370DW Duplex Wireless Laser Printer Logo
62 people viewed this question
Top Brother Computers & Internet Experts
edy copier
edy copier
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
