Question about Neff Watches
Turn alarm off - Neff Watches
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I turn off the alarm on Armitron 45/7042?
To turn the alarm on/off press and hold the top left button. While the top left button is held down, pressing the top right button will turn the alarm on and off.
Nov 13, 2015 | Armitron Watches
I have a phs8905 sharp watch and I can't figure out what AL is I think it's alarm but it doesnt effect anything. The bell symbol turns the alarm on and off but I can turn both the AL symbol and the bell...
A is for ALARM, when you want an alarm to sound just set the time you want to be woken or reminded of something then turn alarm on, an alarm will then sound at the time you set
Mar 02, 2018 | Watches
Can not turn off alarm
If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
Use the 12/24Hr button to cycle through the Alarm options.
When the Alarm bar is blank, the alarm s/b off.
Note: The Casio manuals are online.
http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
Aug 19, 2011 | Casio DB36-1AV Wrist Watch
Turn off alarm for sportline 220/221 stop watch
Press the mode button twice to enter the alarm setting mode, the press the other two button simultaneously to turn OFF the alarm.
The same actions will turn the alarm ON.
Jan 27, 2010 | Watches
I can't turn off the alarm. Please help
to turn the alarm off press the mode button until alarm 1, 2, or 3, appears (as required).
Press the start/split button to turn off the alarm.
Jan 20, 2010 | Timex Lavendar Ironman #T5E971 Watch for...
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Turning alarm offI
how do I turn off the hourly setting
Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
press mode four times until you get to the alarm screen (on mine it is four), then press start/stop to cycle through turn the alarm on, chime on, alarm off, chime off
Dec 26, 2008 | Watches
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
Watches Logo
Top Neff Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Neff Watch Expert? Answer questions, earn points and help others
