Question about Forfex BABYLISS Pro Clipper/Trimmer Combo in Silver
Purchase 1.5mm comb - Forfex BABYLISS Pro Clipper/Trimmer Combo in Silver
How to set up my printer to my Mac Book Pro wirelessly
Since replacing our Wifi and router and purchasing an ATT combing wifi/router
try this link
AT Wi Fi Support and Customer Service
at any rate ATT should be able to give you documentation for your equipment
Jun 24, 2015 | Apple MacBook Pro Laptop Computer with...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Megabind 1 binding machine comb opener is stuck
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 10, 2012 | Akiles MegaBind 1 Plastic Comb Binding...
We have a smell of ***** coming from our window a/c unit. we cleaned out the fan chamber of some mold last week. but i could not clean the fan cage. what could be causing this smell?
There is a weep hole underneith the casing of the unit that has a rubber plug inside it. You press the rubber plug with your finger and hold it in and the water will drain around your finger. If you are outside facing the unit the weep hole is usually on the right side and about four to five inches from the front.
The smell you are talking about is probably coming from the standing water that has come out of the air conditioner and is sitting inside the casing. After you drain as much water out of that casing as possible, go to your local hardware store and purchase a can of air conditioner cleaner. They sell aerosole cans of foaming cleaner that disolves with the condensation of the unit. It deodorized and cleans the dirt and grease on the coils too. Buy a fin comb or appliance comb and use it to remove the hair, lint and debris that collects behind the filter in the vents. That is what the fin comb or appliance comb is for. That should solve your problem.
Sep 20, 2011 | Frigidaire FAS257S2A WallWindow Air...
Ice build up on the coils
To much condensation in the air .. Use a dehumidifier in the room ...
Jul 12, 2011 | Frigidaire FAH106N1 Wall/Window Air...
Forfex BABYLISS Pro Clipper/Trimmer Combo in Silver Logo
29 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
