Question about Frigidaire Washing Machines
My washing is leaking water
It is leaking from the water valve
  • Frigidaire Master
  • 5,323 Answers
CHECK HOSE RUBBER SEALS
Posted on Mar 31, 2015
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
The hot water connection on the washing machine is leaky
The water valve has nylon threads that stripp very easily by crossthreading. You can try some teflon tape on the threads to stop the leak. If not you need a new water valve. est. to repair 225$
Mar 18, 2010 | Whirlpool Washing Machines
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Does the water inlet valve ever leak?washing machine is leaking from up high some where.
Check your hose connections at the rear. Uncouple them with the water off and check the washers inside. If missing or worn it will leak here and dribble down the inlet hose. Also it could be the water valve collar has worn or the water valve may not be pushed into the collar properly.
Oct 18, 2009 | Washing Machines
Water leaking into tub of Maytag la9806
Check the solenoids at the valve. Use a multimeter or ohmmeter to check for continuity. A lack of continuity means a bad solenoid. I'll attach a photo for reference. Hope this helped and best wishes.
Sep 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
