Question about Garden
Jcb digger803 redwater gauge on controle pannel flushed rad also removed thermostat
shaggyrat
  • 1224 Answers
SOURCE: 1999 grand am se v6 3.4
tranny fluid low this could cause the over heat
flushing the rad doesnt always clear the clog sometimes it can make things worst
water pump not flowing properly too much calcium build up inside
if a/c compressor connected the bearings could be seizing slowly maken a drag on the engine to overheat
these are somethings i can think of off the top of my head at this time i hope this helped
Posted on Jun 08, 2008
theroadis
  • 81 Answers
SOURCE: coolant problem
Sounds like you might have an air pocket in the cooling system. This can develop, usually after a service, where the cooling system has to be opened to replace a water pump, thermostat, or other reason. When refilled, the air displaced by coolant has to go somewhere. In many cases, youll find that air is trapped in the highest place it can go...above the level of the radiator cap or overflow bottle. This can be a portion of the upper rad. hose, a heater hose, or a coolant line running thru various parts of the intake/throttle body area. What I do after topping up the system, is let the engine warm to normal op. temp./ W radiator cap still off. When upper hose becomes hot, you know thermostat is open. Now, if a bleeding device is not present, back off a hose clamp at the highest point in the system. Take a pair of pliers and twist the hose just enough to break the seal. You should see steam or drops escaping from your "breach". Once the steam stops and becomes all coolant, you have likely bled all air from the system. Top up radiator and coolant bottle to proper mark and close the system. (tighten your hose clamp) Check for leaks. Keep an eye on your system for a day or two, to insure no leaks are present.
Road
Caution! As with any task that involves opening the cooling system...Coolant and water can become very hot. Hot water and steam can be very dangerous. If you dont feel qualified to perform this task, let a mechanic do it!
Please Rate me by scrolling down to the colored flags and choose which catagory best fits my response.
Thanks.....
Posted on Feb 04, 2009
dennymulford
  • 1055 Answers
SOURCE: no heat 98 gmc pick up just cold air
their is a heat control valve that is by the top of the wheel well it works off vacumme if its not working you wont get heat
Posted on Feb 25, 2009
sawdust46694
  • 398 Answers
SOURCE: new thermostat,waterpump,coolant,block flushed rad
take the thermostat out and heat it up in a pan of water to see if it will open when it gets hot.
you should see it open when it gets hot.use a cooking thermometer to watch the temp. it should open between 180 and 225 deg.
Posted on Aug 04, 2009
SOURCE: overheating in my 1995 Grand Am SE.
its because youre fan does not kick on untill you get to a certain speed or if you just turn on the ac
Posted on Aug 12, 2009
Changed the thermostat and still blowing cold air, temp gauge registering normal now but no heat? took it too autozone and it had either add coolant, changed thermostat or I think act circuit malfunction...
autozone ?? like quick fit in the UK ,confucious say -if you only pay peanuts you only get monkeys-- not what you do is to clamp the two heater hoses that run to the heater radiator ,disconnect these two hoses and then try flushing the heater core rad with a garden hose and keep reversing the flow till no more brown stuff comes out ,then reconnect the hoses remove the clamps and top up engine with it running whilst its cold and replace rad cap and go for a drive and see if it works
Mar 07, 2011 | 2004 Suzuki Verona
Need to flush cooling system of a 2005 chevy equinox and change the thermostat
You can buy a flush kit from your local auto supply store to add to your cooling system for this and future flushing. As for changing your thermostat - simply remove the thermostat housing - remove the old thermostat - replace with new (be sure it is the one rated for the season at hand) - replace gaskets (or use RTV gasket maker) and reinstall housing. Fill the system with proper % ratio of coolant to water (usually 50/50). Drive away happy.:) PS You can find your thermostat housing by following the top rad hose from the rad back to it at the intake manifold.
Dec 03, 2010 | 2005 Chevrolet Equinox
Overheating
According to my owners manual the following items should be checked.1coolant level 2 faulty temp gauge or gauge sensor 3 thermostat stuck in the closed position 4 faulty rad cap 5 blocked water passages in rad,hose,or engine 6 fan blades cracked or missing 7 faulty fan motor 8 improper ignition timing 9 improper spark plug heat range. I think I would start by replacing the thermostat after a good engine flush and replacing the coolant.Good Luck
Nov 25, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
Im trying to flush out the water system what do i have to do first?
First thing you should do is pick up a can of radiator flush and add it to the overflow tank.Drive the jeep with this cleaner in it for a couple of days and then you need to let it completely cool down,remove the rad cap and drain the rad,catching the antifreeze in a pan and dispose of it at a local garage that is authorised to dispose or recycle it.Next step is to remove a heater hose from where they go through the firewall and then remove the thermostat from the thermostat housing and the put the housing back in place.Run a garden hose into the smaller hose of the water pump to flush the engine and heater core,run water into the top of the rad to clean it out,water into the thermostat housing to flush the engine block.
Sep 16, 2010 | 1998 Jeep Grand Cherokee
My BMW 318i has had a new expansion tank fitted after overheating and splitting.After bleeding the cooling system it seems as though the bottom hose is not getting hot any suggestions would be welcome
NORMALY THE HOT FLOW ENTERS THE TOP HOSE AND COOLER WATER LEAVE THE BOTTOM HOSE BACK TO THE BLOCK, SO IF THE TOP HOSE GETS WARM THEN THE RAD IS BLOCKED , IF NIETHER GETS WARM/HOT THEN THERMOSTAT NOT WORKING, OR YOU HAVE BLOCKAGE ELSE WHERE, SO REMOVE BOTH HOSES FLUSH RAD WITH HOSE PIPE, (WHEN ENGINE IS COLD) SEE IF WATER FLOWS OUT AT SAME SPEED AS U R FILLING IT, IF NOT ITS BLOCKED, 2ND REMOVE THERMOSTAT AND FLUSH ENGINE OUT, U CAN BUY RAD FLUSH/CLEANER AND TRY THAT,
Dec 05, 2009 | 2003 BMW 330
1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Aug 23, 2009 | 1998 Honda Civic
Overheating in my 1995 Grand Am SE.
you could try that special stuf for your toilet to flush out any debri plug one side of the radiator real thight fill it with the toilet stuf with boiling water follow the instuctions on the bottle its a thought
Jul 30, 2009 | 1995 Pontiac Grand Am
Radiator whines and overheats when not moving
Have someone flush cooling system & check condition of rad for debris in front of rad & blow or spray it out as necessary. Next time it runs hot, turn your heater temperature up high, blower fan on high, and see if gauge starts to come back down a little. If it does, my guess is your rad needs replacing, or at least consider trying a good reverse flushing of the system first, then rad.
Apr 22, 2009 | 1998 Dodge Grand Caravan
Jcb over heating after 20 min,s there water in the digger
Clean the rad core with air and get a new thermostat .
Apr 20, 2009 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
