Question about Tracfone Wireless ZTE Valet
Wifi authentication problem
Wifi won't connect
Won"t recognize or authenticate any wifi signal whether home, or free signal
Switch to 2.4ghz you may be using 5ghz which isnt compatible - Virgin media superhubs are notorious for this.
Oct 15, 2015 | LePan Le Pan II Android Tablet with 1GB...
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
Why am i getting authentication problem connecting to uverse home WiFi on zte valet tracfone ....any suggestions
try making it "forget" the wifi network, then restart it. then finnaly put the wifi password back in, see what happens.
Dec 09, 2014 | Tracfone Wireless ZTE Valet
None of my wifi devices connect to my Huawei E5220 mobile wifi. How do fix this problem? It keeps giving authentication problem
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Aug 11, 2014 | Huawei Computers & Internet
am having authentication problems with my irulu wifi tab
Feb 01, 2013 | Irulu Cell Phones
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
I have just purchased an eMachine e350, I am having trouble connecting to wifi through the home router(it is on)...I am putting in the security key code but it is saying it is a mismatch...my fathers...
I understood your problem...first check your laptop WIFI is on/off....after switching it on it automatically search for WIFI connectivity arround you...
If your father's laptop find/access that WIFI device then you have problem in code authentication....best solution is that you should remove authentication check....before connecting ..
Second thing is that such a problem cause due to improper installation of of wirless broadcom drivers for your eMachine e350......so ultimately you should re-install wifi drivers from provided CD/DVD...
Restart your device it automatically detect hardware and functions properly...
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 22, 2011 | Acer eMachines 350-2074 Netbook
Tracfone Wireless ZTE Valet Logo
138 people viewed this question
Top Tracfone Wireless Cell Phones Experts
David Payne
David Payne
ka4iup
ka4iup
Are you a Tracfone Wireless Cell Phone Expert? Answer questions, earn points and help others
