Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic TV won't display xbox 360
I recently bought a Panasonic 32" TC-L32X1. I hooked my xbox elite up to it through the component jacks using the cables and it worked fine. About an hour into a game, the graphics mess up (weirdly colored pixels and areas within the game). I restarted my xbox only to discover that the tv will no longer display the xbox.
To be sure it wasn't the console, I hooked my xbox up to my old tv and it worked just fine. I've never had any problems with it, graphics or otherwise so I know it has something to do with the tv.
I disconnected my xbox from the tv and changed all the settings to default. Then plugged everything in again and it worked fine for about another hour and then it did the same thing. I'm trying to get it to work again but I have no idea what is causing it. It worked fine the few days I had it, no problems, and I didn't change the settings at all.
Any suggestions?
SOURCE: Panasonic 32" HDTV keeps turning off
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
nick_helpap
  • 334 Answers
SOURCE: can't get xbox 360 to work on tv
u must use 480 p out put on xbox 360 wqith xcounpunt vcable only 720 p with hdmi on this ok boss thx nick so get xbox on reg tv so u can see pic with yellow cable came with then turn back to 480 p mode ok thx nick
Posted on Oct 12, 2008
mistersony
  • 320 Answers
SOURCE: Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Posted on Oct 30, 2008
  • 23 Answers
SOURCE: My panasonic TC-L32X1 has the power light blinking
its a new t.v, send it back and get another one, or contact the Manufacturer for 1year fac and lab warrenty.
Trust me i am the flat pannel guru :)
Posted on May 02, 2009
  • 53 Answers
SOURCE: panasonic lx-32lxd70 lcd tv not working in cyprus?!?!?!
Under the channel setup menu there should be a way to change the input type of the channel. When you go to edit a channel look for this setting. If all your channels are grainy this is probably the solution also.
Posted on Jun 15, 2009
How do I get my LCD monitor to display my computer correctly
This happens when you're trying to run the laptop screen and the TV at the same time. It's caused because the laptop screen and the TV are different resolutions. Very few laptops can run two different screen resolutions at the same time.
The TC-L32X1 supports a fixed range of resolutions. These are listed on page 24 of the user manual http://shop.panasonic.com/shop/model/TC-L32X1?t=manuals&support#tabs The resolutions are [4:3] 640x480 and 1024x768, and [16:9] 800x480, 1280x768, 1366x768. I would recommend either 1366 x 768 or 1280x768.
What you do next is set the laptop so that it runs the TV only. It's slightly different between brands, but they all use a combination of the "Fn" key and maybe F4, or F5 or F8 or one of the function keys that has the monitor symbol. Press the Fn and the appropriate function key at the same time. The displays will cycle: laptop only -> laptop + TV -> TV only -> laptop only.
Once just the TV is getting a picture, you can use the laptop's graphics tab to change the resolution if the laptop hasn't already done this for you. This does vary depending on the operating system and the video card software. Try right clicking on the background image on the desktop and see if there's a short cut to the Graphics Properties.
Hope this helps
Product Detail
Sep 07, 2014 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
My TV does not have a signal and comes up with the prompt channel 21
Check all the input connection for firmness. Try to make the TV to an auto tune function, after connecting it to an external antenna.
Jun 08, 2012 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
PS3 will not pick up on my Panasonic tv TC-L32X1. Using HDMI and audio outputs
Just use the HDMI (HDMI is Audio + Video) also swap to the Channel before turning on the playstation.
See if that is any better.
Feb 28, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Sep 30, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
348 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
