Question about GE Refrigerators
Digital readout on front of refrigerator
We just got a new GE Model 26 and plugged it in but the digital readout on the front isn't lit up
  • GE Master
  • 4,655 Answers
Still under warranty, call them for pick up. Don't try to fix it yourself. Thanks, Sea Breeze
Posted on Jun 20, 2009
What do the flashing blue lights mean on front of refrigerator?
Flashing blue lights on front of what model Samsung refrigerator?
Jun 12, 2013 | Samsung Refrigerators
Not making ice
Check the ice maker temperature sensor. Mine (model RF265AABP) falls out easily and sometimes the wires break, causing the digital readout to read 88 88 and flash.
Mar 14, 2013 | Samsung RF263BEAESR 26 cu.ft. French Door...
GE refrigerator model number PSS26SGRE SS quit. Lights come on and only digital readout is hours
the mainboard/motherboard in the rear area needs replacing the number is G.E.part # WR55X10942 it merely unplugs and plugs back in with 4 to 8 harnesses depending on your model and accessories
Mar 04, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
GE stove JSP40BB has digital readout all lit up. turning off power did not reset it.
Unplug the range.
Open the control panel to access the clock control.
Remove the wires from the control for 30 seconds.
Replace the wires on the control and plug the range back in.
If this does not clear the control you will have to replace the control.
Jul 24, 2010 | GE Ovens
I have a Ge refrigerator (model # PDS22MIsacc) it seems to be running alright, but the temperature control panel will not light. we are unable to change tempertures.
you will need to replace the main control board located on the rear panel behind an access panel,this board controls all temps and digital readouts,when the readout goes dark this board is the culprit
Apr 27, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
The refrigerator temp lights are flashing on and off and its making a clicking noise..ge profile refrig with freezer on bottom. I unplugged for 5 minutes and replugged with no help
your main-board/motherboard is bad,a telltale sign is,if just recently had light bulbs burn out in the refrige compartment and now they strobe dimly and the digital temp readout is also out and you sometimes hear relays clicking back there, the board took a voltage surge and ruined the circuit trace,replacement is simple,unplug 3 harnesses and snap in new board and plug in new board and youre good to go
Feb 22, 2010 | Refrigerators
Freezer fine, fridge too cold!
You need a new fridge side Thermistor. If that doesn't solve the problem, then replace the Damper Actuator.
Jan 05, 2018 | Zanussi Z32 / 5 Top Freezer Refrigerator
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
Water Filter Reset
Simply unplug your refrigerator and plug back in. The CPU will reset.
Apr 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
