Question about Panasonic PT-47WX49 47" Rear Projection Television
Replaced convergence chips, have new problem
I have a 2005 Panasonic CinemaVision HDTV 1080i pt-47wxc43g, I replaced both convergence chips and now when I turn it on, it clicks and flashes the power light 3 blinks then a pause. I've checked my joints twice, no bridges or voids. I don't electronics in the military and for Magnavox, but I'm stumped and fraustrated
  • 1 more comment
  • coltsfan65 Jun 20, 2009
    I had heard that, which ones are the 2.2, thank you
    I seen those, thank you for the help, I will just replace all, they're cheap
  • coltsfan65 Jun 25, 2009
    well all of my resistors check out fine. could I have bought bad chips? the problem is worse since I put the new ones in
  • Panasonic Master
  • 8,617 Answers
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Posted on Jun 20, 2009
  • Sonny Berry
    Sonny Berry Jun 20, 2009
    They are located at board location numbers R7011, R7012, R7013, R7014, R7015 and R7016
  • Sonny Berry
    Sonny Berry Jun 25, 2009
    Thats possible have you gotten some bad ICs or if they were shipped may have been dropped during handling. ICs are static sensitve so even a small drop could hurt them.
My panasonic cinemavision hdtv is showing double vision. How can this be fixed.
This is likely a convergence problem and if model number indicated here is correct set would need to have both of the stk-392-110 chips replaced and the set adjusted.
Let me know if you have questions.
Sep 10, 2011 | Panasonic PT-47WX49 47" Rear Projection...
We have a PT-47WX51CE panasonic cinemavision hdtv 1080i and the colour is off. We see separated mainly green and magenta and the picture is warped with some lines.
All that mess in picture is due to failure of convergence output chips in this tv.
Replace convergence output ICs (two ICs) to solve picture problem. Required ICs are available in Part Store, click the link to have price info.
Thanks.
Jun 25, 2010 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic cinemavision hdtv 1080i projection TV. Is this tv digital? how does one access the digital aspect?
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Jun 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have a panasonic HDTV 1080i. seeing double images
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Feb 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Faint red bar
This model does not have a bulb. It uses older CRTs.(cathode ray tubes). Your convergence probably is off now. You may be able to re-align it, but between you and me, its an old TV and not worth putting money into. If you can adjust it back, great, it now, Id live with it until you can replace it. check your menu for convergence settings.
Feb 02, 2018 | Panasonic PT-61LCX65 61" Rear Projection...
TNP2AH046 board
Yes. let me know to contact you
May 20, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
693 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
