Question about Samsung RF4287HA
Does not dispense water or ice from the door
Cannot dispense ice or water from the French door. Water filter changed and the ice maker is making ice
SOURCE: RS21DCNS water dispenser isn't dispensing.
your fridge is slowly icing up, you'll next notice the fan being noisy. read this article and ring samsun on the free phone number
http://www.bbc.co.uk/consumer/tv_and_radio/watchdog/reports/consumer_goods/consumer_20080407.shtml
Posted on Jul 03, 2008
eagle338
  • 4889 Answers
SOURCE: Water is no longer coming
I have 'repaired' the exact same problem as yours by opening the door and transferring all door items to freezer proper, then putting plasic lined insulation (can be bought at most big box home centers for about $20 a roll) in the door opening to keep cold air in. Then I taped the interior freezer light to the off position, turned the light on at the dispenser, and checked every 15 minutes by pressing dispense paddle. My water started to flow after app. 30-45 minutes. This is after I troubleshot all other avenues and got to where you are now (disconnected at quick connect just before line enters door) where I also had water flow when paddle was press to dispense).
Posted on Jul 16, 2008
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 122 Answers
SOURCE: I have a Samsung RF267ABRS
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Posted on Sep 03, 2010
  • 2069 Answers
SOURCE: Samsung RFG295AA Ice maker
You could try to Reset the ice maker. there should be a red button by the side of the icemaker. After resetting, wait 24 hours and check if ice production has begun. please also check this very useful guide on how to get on otherwise.
If your ice maker still doesn't produce ice after following all of these suggestions, schedule your unit for service
Posted on Jan 06, 2011
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Samsung RF4287HA Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
