Question about Windchaser Heating & Cooling
Windchaser pacr93 it just stopped blowing cold air and stopped venting hot air like the compressor or something is not engaging correctly. It sounds like its trying to engage but then it doesent so the fans/blowers/motor is slowing than speeding than slowing over and over again, any idea whats wrong with it?
SOURCE: fan motor slow on a/c
If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
Posted on May 18, 2008
22yooper
  • 828 Answers
SOURCE: My blower motor doesn't blow air out the air ducts why
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
Posted on May 27, 2008
SOURCE: Air conditioner works but not blowing out the vents
Check the air directing servo motors under the glove box. they are 2 black boxes about 3"x3". you have to clean the contacts of grease with contact cleaner spray or alcohol.
Posted on Aug 22, 2008
  • 4 Answers
SOURCE: Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Posted on Jan 18, 2009
  • 420 Answers
SOURCE: ac not blowing cold air.
Sounds like the compressor has failed.
Posted on Apr 19, 2009
2002 Merc Sable wont blow air
I'd have to say it's the blower motor. Does it blow hot air when the heater is on?
Aug 07, 2012 | 2002 Mercury Sable
My GMC Sierra's air conditioning works great but the driver side vents will spontaneousely start blasting out hot air. The passenger side continuse to blow cold air. If iI turn the truck off and...
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
May 24, 2011 | 2005 GMC Sierra
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Ac not blowing cold air.
Apr 19, 2009 | 1997 Mercury Mountaineer
Ac blows hot air ac compressor is ice cold but the vents blow hot air when enige is hot. bloows cold air when engine is cold
check your air diverter doors, sounds like the door for heat is open, when a/c is selected the doors should move and close the heater off. the heater will over power the a/c. the door controller is located on the environmental station under the dash neat to the floor. the control is electronic and probably not functioning
Mar 20, 2009 | 2003 Ford Explorer
A/c work for about 1o minutes and then blows hot air. system charged properly, no leaks, a/c machine high and low gauges read good but a/c only works for 1o minutes 97 nissan altima
I Had the same problem, and is the compressor. There is a coil that when receives 12 volts, it moves to engage the clutch, but as is passes about 10 minutes, that coil stop working, so do the compressor, and the system starts blowing hot air. You have to take out the compressor and get to somebody that can change the coil. It cost in parts about 50 bucks, plus recharge the system with new refrigerant. Don't try other test, just go to the compressor put a tester and mesures the voltage at the wires after the security pressure valve on it.
Jul 19, 2008 | 2001 Nissan Altima
Lumina APV air conditioning, randomly
it sounds like a vacume hose is colapsing , there is also a vacume booster it looks like a round black ball and can be failing cheap fix get from junk yard just about $5
Jul 12, 2008 | 1995 Chevrolet Lumina Apv
Windchaser PAC9 (WA9000ER) is on but not cooling...
maybe better to ask: Where's my freon?...somehow it leaked out.
Jun 04, 2007 | Windchaser PAC9 Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
