Question about Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
My brush piece is corroded
My brush won't spin an upon taking the plastic cover off the piece that holds the brush in place on th left side is badly corroded. It's less than a.year old. Is this covered under warranty. Is it fixable?
    Problem Solver:
  • 5 Answers
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Posted on Jan 16, 2015
5 Suggested Answers
SOURCE: Electrolux Oxygen3 model EL7001
If it is the top cover, the monitoring panel just pops off from the backside. You can use a thin knife or screwdriver and push on the locking clips, it then just hinges off of the front clips. After that is off you can see the two screws and after the top cover hinges off the actual door to the vac bags is attached to that cover it too hinges off.
Hope this helps
Posted on May 25, 2008
  • 694 Answers
SOURCE: I am trying to disassemble
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
Posted on Jun 19, 2011
small6363
  • 18391 Answers
SOURCE: I'm trying to find the plastic "lock" that holds the elbow to the power head for a Lux 5000
manual > http://www.totalvac.com/manuals/electrolux_manual_Lux5000.pdf
Posted on Feb 24, 2013
  • 161 Answers
SOURCE: Brush assembly will no longer spin on carpet however the suction from the system is still good. Unit is only 5 years old.
Probably a seized beater roller (the bearings wear out). Just order the new part and replace it and you'll be one your way again. And of course maybe a belt.
Posted on Oct 18, 2013
Does not **** up anything
Your vacuum is clogged. turn upside down so you can see the spinning brush. take a philips screwdriver and remove the screws holding the bottom plastic cover on. remove the spinning brush. take a wire or piece of hanger and fish out all the junk stuck in the vacuum tube.
Mar 30, 2012 | Vacuums
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Where does the piece go to rise and lower the brush
HI There,
The part that raises and lowers the height adjustment goes underneath of the hood on the vacuum cleaner, and is held on by the carpet height adjustment know on the top of the hood.
I've done a repair below that explains how to get the hood off of the roller brush housing, and replace the knob next to it which is the rug/floor selector knob which is the one right next to the height adjustment part. The repair on your machine will be the exact same process however. Hope this helped you:
If you've already changed the belts and the machine still won't run, it can really be only a few things.
The first thing you should check to make sure that the roller brush is good. You may do this by removing the bottom plate, and then taking the roller brush out of the vacuum2_bing.gif. Hold the bar using just your fingertips on the very ends of the brush on the bearing caps. With just holding the bearing caps with your fingers, use your thumbs to try and spin the bar. Does it spin freely without any resistance? If no, then you'll need to replace the roller brush. Here's a direct link to the exact roller brush for your Hoover Windtunnel Self-Propelled:
Hoover Windtunnel Agitator Brush Part # 48414069
If the roller brush spins freely several times on each spin, then your machine may possibly have a bad Rug / Floor actuator arm. This part controls the internal pulley that stops the roller brush when you turn it from carpet to floor mode.
I'm guessing that this is probably a more likely cause of your brushes not spinning. Here's how you can check this part:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt2_bing.gif rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover. On the top you'll see two selector knows, one for the height adjustment, the other that controls the rug / floor setting. Turn the cover over and look at the opposite side of the knob that controls the rug / floor selector. There should be an arm that extends out that looks like this:
Sometimes this arm will break off, which will prevent the actuator arm from activating the rug carpet setting. The machine basically will always be set to bare surface floor mode. Is this arm broken off on yours? If yes, then here's how you can remove it from the machine.
Take your flathead screw driver, and place it underneath of the of selector knob on the top of the cover. Simply lightly pry upwards to separate the knob from the arm underneath:
Replace the actuator arm with a new one and see if this fixed your problem. If this was not the problem, there's really only one other possible thing it could be, but I rarely see this go bad. Please let me know if this fixed your problem, or if it is something else wrong. I'll be happy to then walk you through the last remaining possible problem.
I really hope that this repair was helpful to you. If you did find it to be helpful, help other Fixya users with the same problem find this repair by rating it helpful. You can do this by clicking on the thumbs up icons in the top of the repair.
Thank you very much,
Chris J.
May 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Wind Tunnel U6437-900. The brush will not turn. I have replaced both of the belts with no success. Any suggestions?
The first thing you should check to make sure that the roller brush is good. You may do this by removing the bottom plate, and then taking the roller brush out of the vacuum. Hold the bar using just your fingertips on the very ends of the brush on the bearing caps. With just holding the bearing caps with your fingers, use your thumbs to try and spin the bar. Does it spin freely without any resistance? If no, then you'll need to replace the roller brush. Here's a direct link to the exact roller brush for your Hoover Windtunnel Self-Propelled:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt rides on, and the left side clip is next to the internal hose.
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Apr 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
The belt p/n 0100623 broke - need instructions on how to replace it - we have Bissell ProHeat Powersteamer
I just replaced mine last night. 1) take off the top belt cover. 2) take the water and cleaning solution tanks out then lay the unit on the side so the bottom of the cleaner is facing you (water and solution may leak out so you might want to do this on an old towel). 3) On the same side of the machine as the belt cover but on the bottom you'll see an orange piece (at least it is on mine) that is held in with one philips screw. Take the screw out then slide the orange plastic piece out (might need a pliers to help). 4) there is a black cover over the brush belt that has a tab on it. Pull on the tab and the brush roller on that side will come out of its place. 5) You'll see a cogged belt that drives the brushes. Just slip that off the drive on the machine. You don't need to take it out completely - just off the drive. 6) Slip the new belt (p/n 0100623) in and on to drive. It goes "inside" of where the cogged belt goes. 7) Slip the cogged brush belt back on. 8) push the brush roller and black belt cover back into position. 9) slide the orange plastic piece in place (make sure the belt cover is held in place by it) and screw it back on. 10) flip the cleaner so it is on its wheels again. 11) pull the new belt over the metal drive and manually get it kind of centered. Make sure it isn't touching any protruding plastic. 12) plug in the cleaner and quickly turn it on and off while looking at the new belt. You should see it self center. 13) put the top belt cover back on 14) insert water and cleaner tanks. 15) get to work.
It'll take less than 10 minutes to make this fix (less than 5 probably).
Jun 19, 2008 | Bissell Vacuums
Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb Logo
53 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
