Question about Pilot Pen Pilot Ignition Gas Water Heater, 3 Gal
Wont light I have a wirlpool gas water heater with an ignition button. I have followed the directs like 10 times to see if i could get it to light and it never does. The gas is on. I think the ignition is out or going out. If I turn off the light in the room and push the button i dont see a flash or anything does this mean its likly out?
  • stindall Jun 20, 2009
    no their is a spark or should be it is completely inclosed so i cant get into it. their is the pilot button and an ignition button.
    i am pushing the ignition all the way til it clicks, and their is a small hole that you can see into the heater to see the flame but the hole is also sealed with a glass cover so you cant stick anything into it.
    President:
  • 1,185 Answers
To get it to ignite the gas valve should open and the electronic ignition should spark across the front of the the small jet of gas coming out of the pilot jet
If you cannot see a spark one of two things has happened
(1) The electronic spark generator has died
(2) The tip of the electrode has either broken off or has become so dirty it cannot complete the arc
Either way the only way it can be sorted is to strip it down and check out the ignition circuit
The comment from the previous helper re a long match is not a bad idea provided you realise that you must hold down the ignition button at the same time and in some cases hold it down until the thermocouple has warmed up enough to haold the valve open.
Posted on Jun 23, 2009
    President:
  • 3,433 Answers
Is there a spark? or do you need a long match? The button usually just opens the pilot so it can be lit. If its not electronic.
Posted on Jun 20, 2009
  • Ned C Cook
    Ned C Cook Jun 20, 2009
    You should be able to hear the spark like on a gas stove or bbQ. From what you say, it is the ignitir. And you say there is no access, hmmmmmm, they had to get all that stuff in there somehow.no peep hole you can slide a long match of bbq litter into? Are you pushing the ignitor button down all the way until it snaps? Just holding it down won't do it. You have to make it snap. That makrs the spark.
  • Ned C Cook
    I know your finger must really be sore by now. It seems you have tried it in every possible way. But, I'm going to ask one more question.....never mind, I think we will just have to admit defeat. The ignitor wins by fault. I'm sorry. You tried. co7196@yahoo,com if you come up with an idea e-mail me.
Have a richmond 6G40-36F1 hot water heater had to turn off gas for another issue, now igniter doesnt spark and pilot wont light
Not to sound silly, but are you pushing the igniter button down hard enough so it snaps? If so, your igniter is no good. Try to light the water heater the old fashioned way by using a match. I would use fireplace matches since they are long enough to reach the pilot light point.
May 27, 2016 | Water Water Heaters
Finally found the reset button on my Whirlpool hot water tank, but it will not budge when I push it. Why? Pilot will not light.
Reset button on gas water heater??
Usually there is not a reset button on gas water heater, which might explain why is doesn't move:
Do you mean the igniter button for lighting pilot?? The piezo igniter can go bad.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment with description of water heater, and more detail or call plumber.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 23, 2013 | Water Heaters
My brand new 38 gallon GE water heater does not ignite. I follow the instructions, hold down button in pilot position, heater dial in pilot mode and push the piezoelectric button several times. I look...
Check that gas is turned ON. Gas handle is parallel same direction as gas line.
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Make sure that type of gas matches water heater. Natural gas and propane gas are two different types of gas. check label on side of tank for type of gas NG or LP.
Call GE 1-800-432-2737
Copy following links:
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Aug 11, 2013 | General Electric Water Heaters
My red light is flashing
Gas water heater?
Copy following link to troubleshoot be gas control valve:
Add comment and describe type and brand of water heater
Mar 29, 2013 | Bosch & Tankless LP Hot Water Heater
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instruct8ons
1) Just open the following link to identify gas control, and following instructions for lighting each gas control that appear under the gas control that looks like yours.
2) Otherwise add a comment and carefully describe gas control valve, and then open link and compare your description to pictures of each gas control valve, and then look below each picture for link that says how to light water heater.
3) Call plumber.or local service technician, or local BW supplier who can recommend technician.
4) Call Bradford White to get recommendation of local technician.
Trying to reset pilot light per instructions. Something is missing.
1) Copy following link to identify gas control valve:
2) Add a comment and describe gas control valve, and include if this is on boiler or water heater
My Power went out and was out for 1 1/2 days. It must have affected my water heater as well because my water is constantly cold will not warm up. i notice the water heater ignitor isn't on and after...
Could be bad regulator valve. Make sure you follow the lighting directions to the TEE. But if it will not light at all in pilot mode, its most likelt a the regulator valve.
Oct 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
We had to turn the gas off to connect the dryer, now we can't get the pilot light to turn on. we followed the directions on the water heater 5 or 6 times with no luck. It seems the pilot light will not...
I would suggest that you remove pilot assembly from gas valve and burner and clean pilot orifice and see if that helps. Be careful when cleaning hole in the orifice so you don't enlarge the hole. Good luck and thank you.
Jan 02, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot Pen Pilot Ignition Gas Water Heater, 3 Gal Logo
514 people viewed this question
Top Pilot Pen Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Pilot Pen Water Heater Expert? Answer questions, earn points and help others
