Question about Kenmore Dryers
Replace kenmore dryer belt model 110.62212100
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: Replacing the belt on my kenmore electric dryer model # 110.8756.
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and clean out the dryer. Oil the wheels and idler. Replace the belt using this diagram . NOTE yours is lower right:
Posted on Dec 22, 2008
dragonsthatk
  • 547 Answers
SOURCE: Replace dryer belt
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
erpaalai
  • 999 Answers
SOURCE: replace belt on kenmore 97281100 dryer
You have to remove the front panel. The top folds back and there are 2 screws on the inside corners to release the front. Eric
Posted on Sep 12, 2009
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
How do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Apr 26, 2010 | Kenmore 62602 Electric Dryer
Trying to replace the dryer belt on a Kenmore Dryer
Good day,
That is a known defective part. Go to any appliance parts house and get the model with a wheel on it. The counter men will know what you need. Yes, it's made by Whirpool.
Directions below.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 05, 2009 | Kenmore Dryers
How do I access the belt on my Kenmore model
You have to get behind the dryer and remove the back. This will give you access to basically everything.
Nov 14, 2009 | Kenmore Dryers
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Dryers Logo
18 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
