LeapFrog Leappad Plus Writing Logo
A
Anonymous Posted on Apr 21, 2014
Won't start the program - LeapFrog Leappad Plus Writing
Smeg dishwasher ( DWA6314x2) program panel won't light up.
Hi Amanda.
this link might help you out.
https://www.google.com/search?client=avast-a-1&q=Smeg+dishwasher+(+DWA6314x2)+program+panel+won%27t+light+up.&oq=Smeg+dishwasher+(+DWA6314x2)+program+panel+won%27t+light+up.&aqs=avast..69i57.6774j0j9&ie=UTF-8
2013 Buick LaCrosse “no remote dectected” car won’t start. Changed battery in remote fob..car started .. next day same message and car won’t start.
The best answer is inside your owner's manual Section 2 page 6. I believe you have to program your key fob. The HOW TO is there;
Hope it helps.
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 • Dishwashers
My SportsArt 7100 Stepper has no resistance and won't start any programs
RUN the software calibration for easy diagnose and troubleshooting.
God bless you
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
6helpful
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
I dropped it and now it won't work. It starts but there is a knocking noise and won't select movies or do anything.
Remove media player from CPU ("Add and remove Programs" or "Programs and Features" both under control panel), then Google Windows Media Player, free down, if that doesn't work, its most likely a hardware issue. Hope it works!! :)
1helpful
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
