Question about Canon PIXMA MP620 All-In-One InkJet Printer
Can't print from my Apple Laptop.  Error message reads "306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again.
  • Michael Grey
    Michael Grey May 11, 2010
    Sre using wi-fi or usb?
    Which OS,Tiger or Leopard?
    Sergeant:
  • 361 Answers
Frist u should check your printer port is install o r not in your computer . right mouse click on my computer then click onhardwere, then click
port,if not stall there is yello sign. instail it.
2/ if not work.re install softwere driver once a time.
Posted on Jun 20, 2009
What's your problem?canon i9100 error 306
When you attempt to print from your Canon Printer using a Mac, a message appears stating Error 306. Solution
  1. Click the Apple icon in the top left of the screen.
  2. Click System Preferences.
  3. Click Print & Fax.
  4. If the padlock in the bottom left is locked:
    Click it, enter your password and click OK.
  5. Click the - button. to remove the printer and the + to add it again leaving the options on default..
May 18, 2012 | Canon i9100 InkJet Photo Printer
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
Error 306 can't get printer to work with my mac. It was working just fine until I changed the cartridges and now it gives me an error 306
Error 306 is a communication error and should have nothing to do with the cartridge. Check to make sure the printer is plugged in and restart your computer, and try again.
Jul 25, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Error 306
A communication error has occurred. reinstall drivers or change usb cable
Mar 19, 2010 | Canon PIXMA MX310 All-In-One Printer
Every time i try to print, the computer doesn't seem to see the printer and it stops the job. error message # 306. very aggravating!
That error message usually means you have a communication error. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again
If that doesn't work, try this:
1. Start Home Applications, go to Utilities, select Utility Printer Setup
2. Hold down the "option" key and click on "More Printers" button
3. From the main menu, select "Advanced"
4. In the next dialog box, under Device: select field "LPD / LPR Host or Printer"
5. In the device of the "URL:" lpd://PCName/PrinterShareName
6. Click the "Add
If that doesn't work either, check your router settings.
Mar 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
Unknown error occurred (306)
some people have been doing this
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
do a google search for "itunes error 306" for other discussion boards on the topic, seems to have occured after an itunes update conflicting with OS (go figure right?)...hope this helps =)
Feb 04, 2010 | Apple iTunes
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Canon MX850 keeps saying Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. I...
It is possible that your ink cartridge is damaged. Try using an old ink cartridge that worked before and try to print again.Even if the ink cartridge you are using is full of ink, when sensitive electrical components are damaged, it wouldn't work.
You can also try using a different printer to rule out the possibility that your computer is the problem.
Sep 06, 2008 | Computers & Internet
Canon PIXMA MP620 All-In-One InkJet Printer Logo
556 people viewed this question
old marine
old marine
