Question about Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Bosch 1590EVSK Problem
It just stopped working. No power getting to it. Plugged it in and after a couple squeezes on the trigger it just died. Anyone know if there is a safety or reset button anywhere on this? thanks.
  • 285 Answers
No safety or reset. The problem is likely to be a bad connection somewhere inside the jigsaw or dust around/inside the trigger assembly. If it is new or recently purchased, seek a replacement. If out of warranty, you could try disassembling it and checking for loose wires, or using an appropriate multi-meter to check where the current is absent and go from there.
Posted on Jun 20, 2009
How to fix trigger on Bosch aquatak 1200 pressure cleaner
Are you able to squeeze the trigger or is it locked closed?
Sep 23, 2014 | Garden
My Bosch PST 650 has suddenly stopped working. I have checked the fuse and general things but it still doesn't work. Any Ideas???? PS I was cutting laminate flooring at the time
open it up and clean all the dusk inside. probably it's stuck and can't start the mechanism. That's what i did with mine. Working perfectly again.
Aug 08, 2011 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
The motor keeps cutting in and out, like the variable speed control is confused. What can I do?
There are a couple problems that could cause this. First is the trigger switch which could be worn out or have a short. The second and more common one is that the motor brushes are worn out. After a long period of use these little blocks that look like black steel blocks on springs are what rub on the rotor and they wear out. These are not steel but special high carbon blocks that are easily replaced and cost effective. Remove the housing and near the rear of the motor assembly you will find the brushes in two square holes on either side of the motor. Remove them (be sure it is unplugged) and replace them with new ones. They can be ordered directly from Bosch or from a host of suppliers on the internet.
Oct 24, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
DROPPED MY BOSCH 1590EVSK JIGSAW, REPLACED BENT BASE, BUT BLADE IS STILL NOT PERPENDICULAR TO BASE. CAN'T SEE ANY ADJUSTMENT METHOD TO ALIGN BLADE PERPENDICULAR TO BASE PLATE. HELP
The socket-head screw that holds the sole plate on is also the alignment screw. Loosen it a little and the sole plate will swivel left and right. There are graduation marks on the base to help with alignment but I always use a square to verify the alignment. Tighten the screw and check again that it didn't move and you are ready to go.
Aug 20, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Dear Experts, I need assistance from you ppl.I stay in India. I bought a medium quality glue gun and a glue stick. I plugged the gun to the power socket(220v)and waited for the glue to come out of the...
It takes a couple of minutes for the gun to heat up. When you first plug it in, touch the metal nozzle with your hand. It should become obviously hot within 15 seconds and too hot to touch within a minute . After it fully heats up (a couple of minutes), squeezing the trigger should advance the glue stick and push molten glue out of the nozzle. However, there is often an initial resistance to the trigger and you may have to squeeze a bit hard to get it started. If there is a problem with the trigger mechanism, you can also advance the glue by pushing directly on the back end of the glue stick with your thumb. Good luck.
Aug 04, 2010 | Garden
The switch is intermittent. The saw has #5375 on the nameplate. I t has the two-handed safety switch where you have to push the red one with one hand and squeeze the trigger with the other hand. Sometimes...
Simply the switch will need replacing and this can be obtained from the mfr or you can get it repaired at a local tool repair center. Get it replaced asap.
Sep 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
My 9 month old Bosch 1590 jigsaw will not start??
The problem is the switch, or trigger switch. It may just have saw dust in it or it may be shot. Try blowing the dust out of it with a good blast of compressed air. If you don't have a compressor to do this go to a tire shop. They will help u.
Jun 20, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw Logo
239 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
