Question about 2007 Chevy Colorado - 3.7L 5-cyl. engine - Performance Module
P1400 code on my 2007 chevy Colorado 3.7 liter
Problem code
What year?
2007 Chevy Colorado 2.9 liter
Mar 11, 2015 | Vehicle Parts & Accessories
P1400
Problems with the intake manifold, a vacuum leak in the exhaust and proper gas recirculation can produce these codes. p1400 codes,
Jun 08, 2014 | 2007 Chevrolet Trailblazer 4.2
Code PO106
i put a cam valve on my 2007 colorado 2.9 part number 12615873 @ the chevy dealer $ 61 today
Aug 14, 2012 | 2006 Chevrolet Colorado
Can you tell me the answer for code P1400 for 2007 Trailblazer
P1400 - Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)
Jun 08, 2012 | 2007 Chevrolet Trailblazer
2007 chevy colorado DTC code P2610
BEFORE ANY THING. CK YOUR CABLES TO THE PCM. TAKE THEM OUT AND PUT THEM BACK IN. ALSO, MAKE SURE MASS AIR FLOW CONNECTIONS ARE TIGHT.
Jan 11, 2012 | Chevrolet Chevy Cars & Trucks
How do i fix the problem for a p1400 code on a chevy trailblazer 2007
Check for a restricted air cleaner, vacuum leaks, intake manifold leaks, exhaust leaks, to name a few things.
Sep 15, 2011 | 2006 Chevrolet Trailblazer Ext
What are the trouble codes p1400 and p0506for 2007 chevy trailblazer 4.3 6cylinder
Go to Auto Zone ask the technician to run a computer scan and print out the results and the computer will tell you the meanings of the trouble codes.
Jun 17, 2011 | 2006 Chevrolet Trailblazer Ext
How to remove the car stereo from 2007 Chevy Colorado
This is not hard but tricky because the trim plate around the radio has clips that hold the trim plate very tight.Use a plastic type flat tool or flat screw driver wraped with tape or a shop rag to avoid damage to the plastic trim and pry the trim panel around the radio loose. remove all elec connectors.Then remove the screws that hold the radio in place and remove all elec connectors.
Jan 30, 2010 | 2007 Chevrolet Colorado (Extended Cab) New...
Engine specs
you can usually find those specs at a local repair shop,or your local Chevy dealer.also some auto parts stores
Nov 20, 2008 | 2007 Chevrolet Colorado (Extended Cab) New...
2007 Chevy Colorado - 3.7L 5-cyl. engine - Performance Module Logo
50 people viewed this question
Top Jet Vehicle Parts & Accessories Experts
Roger W Stone
Level 1 Expert
Richard Warren
Richard Warren
Gil Shultz
Are you a Jet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
