I have a resistor blown on a ad301m24 4n1 power supply and dont know the value the colours are red white silver gold yellow.or r41could u tell me value please
  • 191 Answers
SOURCE: AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
hi isolate ur power unit out replece ur resisitor & every other burnt items then check the schottky diodes in the secondary side &the electrolytic capacitors if bulgge or leak. if all this are ok , power then use voltmeter to test ur output voltages if ok , unplug your inverter  & power
Posted on Nov 10, 2008
SOURCE: Power supply AD-12014(I) two smd burned
223 both
Posted on Mar 02, 2010
budmrtn
  • 11361 Answers
SOURCE: R5 Resistor blown. Cannot find specs, or where to
Is it the surface mounted resistor? Pictures will help. budmrtn@aol.com
Posted on Jul 22, 2010
lovejoy91
  • 691 Answers
this is because R001 is not 5.6 ohms, it's 560K ohms
Posted on Jan 11, 2011
  • 5 Answers
SOURCE: LG 23LC1RB TV Capacitor blown on
try this link
capacitors.best-price.com
hope this helps?
Posted on Mar 11, 2011
Need the value of a resistor ?
that's a really strange color scheme , are u sure about the silver could that be white instead ? cus that be orange/blue/white ( 31000000000 ohms) with 1% tolarance
Sep 15, 2016 | LG EAY60968701
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
Sanyo tv model ST21G1 chassis AC5G, will you please help me find the value of R617,power suppy section,thanks.
look for the colour code on the resistor and then look it up on a chart ,different values between a silver band and a gold band but the value is the same its just the % tollerance ,gold band is a lower tolerance
Jan 25, 2011 | Yugo GV Cars & Trucks
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Power supply is only 12months old very little use. Was working fine but one day failed to turn on..its not overloaded its rated way,way above what my system should need. Being an auto electrician I thought...
Hi
This resistor is for overload its like a protection unit your system may Overload but you need a multimeter to test the Diodes and you might find that one of them is short this can cause the resistor to blown
you can find this resistor in High Voltage circuits
hope it will help
ecrdn@yahoo.com
Jack
Nov 02, 2010 | Thermaltake 700-Watt Power Supply
I have taken out my standerd sterero in ford fiesta 1996 and cut off the block dont know what wires are what and now clock dont work ant think i have blown the stereo can any one tell me what wires are...
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
Apr 13, 2009 | Car Audio & Video
RCA L42WD22
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
Apr 03, 2009 | RCA 20F511T TV
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
DVDPlayer/Freeview box (believed to be a generic one with a Wharfedale label)
R10 just means Resistor # 10 unfortunately this is just to make the manufacturing process easier.... However reistors are marked with their value(using coloured bars), if you can read the bars you can get a replacement for it, and hence if you can decode the bars you will know what the value of that resistor is Black = 0 Brown = 1 Red = 2 Orange= 3 Yellow= 4 Green = 5 Blue = 6 Violet= 7 Grey = 8 White = 9 therefore if you have a sequence of red green black then you have a 250 ohm resistor, gold, silver and bronze bands on the other end of the resistor designalt tolerance and should be noted Just hope that it was only the resistor that got toasted Good luck
Oct 04, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
