Question about Clothing Accessories
Make a square paper hat from newsprint - Clothing Accessories
How do I clean the paper from around and behind the rollers?
Forget the cardboard and feed in less sheets at a time.
It overheats because the motor is working too hard.
Aug 20, 2014 | Cross Sentinel 10 Sheet Cut Shredder
How do I clear the paper clog from the rollers?
First try to run it backwards. Sometimes that will clear a clog. If not UNPLUG IT, and painstakingly pick out any paper lumps with tweezers, slowly. GOOD LUCK! I have spent a few hours in front of the TV just picking out paper bits. In the future, be sure not to put in more than two or three pieces of paper at a time, NO STAPLES, and use shredder oil ever fifty or so sheets you put through!!!
Mouse will not move items and keeps jumping around
As your PC is new, it's likely you have an optical mouse. Sometimes they are unable to sense movement on certain surfaces (glass, pure white paper etc). Try putting something under it - magazines or newsprint normally works well.
Apr 23, 2013 | Computers & Internet
How do you make hats for kids out of paper plates? My neighbor said it was easy but I need some help.
Really all you need to make some fun hats for kids is a paper plate and scissors. The bigger the plate, the bigger the brim on the hat will be. Fold the plate in half and cut out a circle where the kid's head will go, but leave a section to cut out a shape or design that will stand up in the front of the hat. Now you can give it to your kids to decorate or color in.
Mar 04, 2013 | Clothing Accessories
I need to buy party hats for our kindergarten. Any suggestions of places that are not too expensive?
I like the Dollar Days site as they have a good range but have wholesale amounts or quite competitive prices.
http://www.dollardays.com/wholesale-party-hats.html
Although their hats all seem to be themed ie Pocohontas.
Hope that helps.
Feb 25, 2013 | Event Planning & Celebration
Bolt torque specs
I have used Haynes service manuals for (hate to admit it) many decades and I recommend you check to see if this one:
http://www.amazon.com/Haynes-Toyota-Automotive-Repair-Manual/dp/1563923513
doesn't cover your engine.
I have found darned few 'holes' in their coverage.
Auto parts stores carry these and I suspect that even though sealed, the sales people will not give you too hard of a time if you explain you want to insure you are getting what you need.
Haynes is not the same as it was 20 years ago before they were acquired by Chilton but the price/utility ratio is still pretty good.
Mostly I'm annoyed by the move to cheaper paper (newsprint)that is fussier, picks up dirt, tears more easily than the better paper of yore.
Aug 09, 2008 | 1995 Toyota Camry
Lawnmower lbade assembly sequence
1. install round washer first flat side facing you.
2. round plastic washer next flat side facing the washer.
3. next step blade.
4. next step square plastic washer label facing you.
5. then the square metal washer, make it flash with the shaft flat side.
6. tighten nut by hand at first then use impact tool if you have.
Jun 08, 2008 | Black & Decker 19" Electric Lawnhog...
Curling
The paper is definitely your problem. I suggest you try all types of paper settings that are available on your machine. I think there is a recycled paper setting.
Feb 22, 2008 | HP LaserJet 1320 Printer
Clothing Accessories Logo
85 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
