Question about Pentair Pool & Spa
Service manual motherboard
Spa remote does not work
    Top Expert:
  • Pentair Master
  • 8,471 Answers
Possible bad remote water gets in to cord
Posted on Nov 16, 2017
The remote will turn on but cant use any buttons
out on the control box, there is a service button. when your service guy is working on the pool, it should be on either 'service' or 'timeout'. in either of these modes, your remotes will not work and the timers are disabled. go to control box and set the system to 'run'
Sep 14, 2015 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
RPS Code
remote pool and spa if no control take off tstat remote and put on manual
Mar 05, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have an intermatic RC3621RT 5 circuit timer with remote controls for the spa. I'd like to upgrade, but I cant find a cross reference for a new box that would be the same. Can you help?
Following pdf file shows Intermatic pool and spa controls
http://waterheatertimer.org/pdf/Pool and Spa.ashx.pdf
PE40000 series has remote control and 5 SPST circuits (3 timed with timer and 2 on-demand with remote control). Can be wired for both 120V and 240V circuits, so pump can be 240 and lights 120, or both 120.
The new timers are electronic
Intermatic pool and spa website with contact-us information & manuals:
http://www.poolandspacontrols.com/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Intermatic Hardware & Accessories
Intellitouch 9.3. Three years old, been fine till
I've been having the same problem - I don't have the complete solution but can tell you what I've been through so far. After 4 service calls and a visit from the local Pentair rep, they have replaced both circuit boards on the personality board. When they reconnected the spa-side remote, the electronics circuit tripped again. They are telling me I need to replace the spa-side remote, but I haven't since the repairs to date have cost me $1700 and they want another $700 to replace the spa-side remote. $2400 for a system that's 5 years old is ridiculous so for now I'm on hold, especially considering it may have been the spa-side remote all along. Don't know if your system includes the spa-side remote - if it does, disconnect it and see if the problem resolves itself, the remote may be the culprit.
Jun 13, 2010 | Pentair Intellitouch Pool or Spa...
PDA quit working and cannot override the system on control panel
I had a problem simmular to yours When I changed my remote I had to also change my antena. Also make sure youd dip switch settings are set the same. between the antena & remote. The only reset that I know of is in the remot. Go to Menu then System Set UP. Then clear Memory. You Will loose all programs like, Dimming relays temp settings times for off & on. etc. I think if you have a intella flo motor you will have to reset it also.
Oct 04, 2009 | Jandy AQUALINK RS TELELINK KIT
Spa turns on by itself.
if no spa programs remove spa side remote if it goes away replace remote
Mar 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Philip hd flat screen
first time I have seen a spa tv lcd fail, sorry but I can tell you it is the capacitors in the tv that have issues they will have to be re[placed call a service tech that can take the tv in for electronic work if you want to spend the money or you can replace the whole thing for probably less money than repairing the old unit, by the way if you have a tv in a spa the humidity is well past the operational limit of the tv components
May 28, 2008 | Philips 15MF170V 15 in. HDTV-Ready LCD...
Pool & Spa Logo
66 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
