I have a sony tv, and i am trying to use the basic xlrc001 remote but i cannot enter the code to set it up
Gigatech
  • 259 Answers
SOURCE: codes
You will find the codes in the manual
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
IrishDruid
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: TRYING TO PROGRAM MY NEW SONY RM-YD024 REMOTE
Try these
For Direct TV:
00099, 00247, 00392, 00566, 00639, 00749, 00819, 01076, 01108, 01109, 01142, 01377, 01392, 01414, 01442, 01443, 01444, 01609, 01639, 01640, 01749, 01856, 20739
For Panasonic Satellite receiver:
00247, 00701
You can also look here:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMYD024
Posted on Dec 23, 2008
  • 9 Answers
SOURCE: UMC J20/1U12G Set - Need Remote Control Code
http://www.remotes4u.co.uk/show_models.php?brand=UMC
Posted on Mar 10, 2009
SOURCE: My Direct TV RC64R remote won't work
Yes 10030 is the code. Many Thanks to the Guest.
Posted on Apr 11, 2009
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
Digitron dvd
Sony remote control have no setup code to this "Digitron" brand. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 18, 2014 | Sony (RM-V301) Remote Control
ETec RE7 code for Sony tv & dvd player
This brand remote control have no setup code to Sony TV/DVD combo. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
Jan 14, 2014 | Televison & Video
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Aug 29, 2011 | Televison & Video
I have a Quantum FX Mini Jumbo 8-Device Universal Remote Control and i lost the booklet so i need the codes for a Sony T.V. and i need the intructions for entering the code. Thank you for your time.
Sony codes are 0414,0902,0801,0708,0639,0816 press and hold tv button until light comes on enter the 4 digit code light should go off try volume or channel or something to see if it works if so your good to go if not try the next code.
Emerson codes are 0002,0502,0006,0115,0506,0706,0520,0906,0316,0505,0614,
0622,0324,0924,0626,0826,0027,0327,0128,0228,0305,0063,
0134,0247,0605,0705,0805,0703,0090,0004,0519,0106,0104,
0304,0604,0804,0005,0105
May 29, 2011 | Televison & Video
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
I have a Sony Universal remote that I am very happy with until now. I have it running with my Zenith tv but the remote seems to have losr its codes and I can' t find the sheet of paper they were on. It's a...
The codes are ,8010,8121,....turn on TV,press SET, press TV,enter code, press enter, press POWER, try another code if it dont work...hope this was helpful..
Apr 26, 2010 | Televison & Video
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
I have a sony tv and a one for all remote control it is not working. someone gave me this so i need to set it up
try this CODE , taken from ONE FOR ALL Universal Remote URC6012W : code 0000
To set up remote : first turn on TV , on the remote press device key ( TV , VCR , DVD , SAT ) youre going to program , press and HOLD "set" until red light blinks twice then release SET. Enter code " 0000 " , if performed correctly you will see the RED light blink twice. AJ
Nov 23, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
May 09, 2009 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
