Question about HP Compaq Presario SR2150NX PC Desktop
Won't shut down when click shut down
The only way to shut off computer is to hold the button on the tower
  • tiggermej Jun 19, 2009
    how do i do that
U need to format the system, it seems thtur OS is being corrupted.
Posted on Jun 19, 2009
  • Anonymous Jun 19, 2009
    it can only be done with an original OS cd and an expert needed to do that. i would suggest to visit techbuddies. they will help u to diagnosis ur problem at a very cheap price.
    link
    http://tinyurl.com/m7ghqz
MONITOR Dell older model says no signal
The first thing to check is the cable between the tower and the monitor. If you have done this, then hold the power button until the computer shuts off...wait 5 seconds and then turn it back on. If these two things do not work, then it is likely that the integrated video part of the mother board has failed.
Feb 25, 2013 | Dell Computers & Internet
I can't reset my dell desktop computer
Uplug from AC at rear of tower wait 30 seconds plug in start normally.If that fails push and hold button until it shuts off. Use the second part of this procedure, http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&l=en&s=dhs&docid=DSN_325300&isLegacy=true
Nov 28, 2012 | Computers & Internet
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
I was wiping the keyboard and my tower turned off. Obviously I have hit a button or combination and cannot get the tower to turn on.
If you didn't have anything important running on the computer, that hasn't been saved already.
Then hold down the power button on the computer until it shuts off.
Then wait a few seconds and power it back on, you should be good to go.
Feb 15, 2011 | AOpen KB-858USB (9000029UB2) Keyboard
I have Windows 7 on my Asus desktop. When shutting down I accidently clicked on Sleep. No I can't wake up my computer. I have tried pushing the moon button on the keyboard and restarting my computer as...
If I were you I would just press and hold the power button on your computer tower until it shut's off and then turn the computer back on. I assume that since you were shutting it down that you had nothing important open, so forcing it to shut down won't hurt anything.
Dec 13, 2010 | Computers & Internet
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
I am running winows xp my moitor is stuck in sleep mode and I can not use my keyboard
Try restarting your computer, when you have the system up check your power management features.
Hope it helps!
Feb 14, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Flashing Green Power Light on Tower
Try holding down the power for a full minute or two then start it up again. The power button may be set for sleep and not shut down. You may have to hold the button longer. If that doesn't work it could be RAM, or a serious problem with the motherboard.
May 06, 2009 | Dell Dimension C521 PC Desktop
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
HP Compaq Presario SR2150NX PC Desktop Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
