Question about Vehicle Parts & Accessories
1998 caravan engine stalls when hot, will not pull hill without stalling, hard time starting when hot
Seems to be getting too much gas, air mixture not correct
    Sergeant:
  • 250 Answers
Check the air filter, it may be blocked
Posted on Oct 22, 2014
2 Suggested Answers
  • 13 Answers
SOURCE: When i switch on the engine it sounds that it is going to stall and seems to me that engine power produced isis less
check for major vacuum leaks such as power brake or pcv value
Posted on Jul 02, 2014
No power on exceleration smells like gas hs a hard time pulling hills 94 saturn sohc 1.9
Start by replacing the air filter and checking the operation of the fuel pressure regulator. Have the stored codes read out of your ECU, either by an auto parts store or a local mechanic, in order to ascertain a starting point for diagnosis.
May 08, 2015 | Saturn Cars & Trucks
1998 dodge caravan
Fix the overheating problem, first.
Apr 21, 2014 | Vehicle Parts & Accessories
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
I have a 1994 Toyota pick up 4 cyl 22re engine and it revs up and down once warmed up. So once its warmed up if you step on the brakes it starts to stall or does stall. When I first got it It blew...
code 22 is for a faulty coolant temperature sensor. I suggest you change it. This sensor tells the truck's computer when the engine is fully warm. Without it, the computer is guessing at the fuel mix and it seems to be wandering around. Note: this sensor is different from the one that sends information to your coolant gauge. The gauge sender has only one wire coming out. The engine coolant temp sensor has two wires.
I would also have the brake booster tested for a vacuum leak. The engine stalling when the brake is depressed sounds like it is getting too much air and leaning out. If the brake booster is leaking and won't hold a vacuum, the extra air getting into the fuel mixture could also cause rpm fluctuations like you describe.
Jan 31, 2011 | 1994 Toyota Pickup
Have a 2005 ktm 525 exc,after 20 mins of riding it starts missing and stalls when slowing down for gate or log ect,when i try to start it takes a bit and will pop or backfire through exhaust, had jd kit...
sounds rich, especially if its a problem when it warms up, was the JD kit a much bigger main jet,might need to try standard main, is it standard exhaust, I assume the air cleaner is clean and good condition, the foam can deteriate over time.Not sure if you have a hot start button or lever, this leans the mixture, if you have one and it helps then its definately rich
as a non related hint I use moreys upper cylnder lube in my WR it starts easier, idles easier, doesnt stall as easy under hard braking, and doesnt seem to get as hot and ping when working hard in tight bush.
Apr 28, 2010 | 2005 KTM EXC 525 Racing
Engine hard to start in the morning. It stalls as if no gas
Possibly a faulty pcv valve or vacuum hose split, or fallen off.
Aug 19, 2009 | 1990 Dodge Caravan
1995 geo prizim 1.8l stalls when hot, hard to start after words
I think i have air in my clutch line and it is going to the floor my fluid was low now my clutch is working a little here and there. how do i get that air out of the line?
Aug 13, 2009 | 1995 Geo Prizm
Dies while driving
If the engine stalling occur when the engine is hot the most probable cause is a vapor lock, this is when gas boils before it reach the engine, when the engine is extremely gets hot, the gas boils and an air bubble is formed which causes the air/fuel mixture to be too lean, too much air and not enough gasoline, thus making the engine to stall. When you experience vapor lock, just let the engine cools down, have a mechanic to check your cooling system it might cause the engine to get extremely hot.
Engine stalls while driving a vehicle with carburetor
Apr 09, 2009 | 2002 Nissan Sentra
98 accord stalls out
When your car will not start check to see any sparks, if no sparks at all replace the distributor . I thinks it should help
Mar 27, 2009 | 1998 Honda Civic
Can't keep running seems to flood out 1978/79 kawasaki
check the timing it sounds like your problem is there
Jan 13, 2009 | 1976 kawasaki KE 125
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
