Question about Maytag LSG7806A Front Load Stacked Washer / Dryer
How to remove cover of maytag washing machine
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washing machine is not spinning out the water from my clothes once its done washing. My clothes are still soaked even after its done and theres a little bit of water left in the...
you have a partially blocked drain from the tub down thru the pump to the drain pipe,remove the lower front cover and remove the drain cleanout and check for blockages in these hoses
May 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Model # LAT9593ABW washing machine leaking - cannot get the lid / cover off to check where the leak is starting. thanks
This page shows how to remove the front. Also if the tub seal is bad (video shows how to tell) there are directions on how to replace it.
http://appliance-repair-it.com/Maytag-tub-seal.html
Sep 21, 2010 | Maytag Washing Machines
Maytag A712 washer. Water pours out.
Maytags last great washer! This model was top of the line from 1985-1988
The leak can be coming from many different places. Pull the front cover off and we'll go from there. To remove the front cover, loosen and remove 2 phillps screws near the bottom of the front cover. Lift the cover at a 90 degree angle and the cover will pull off.
Sep 29, 2009 | Maytag Washing Machines
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
Trying to replace the motor on my maytag toploader washing machin
Hi There,
On the bottom of the front panel there should a philip head screw right above each fron adjusting leg.
Remove these 2 screws. Open the cover and lift up on the front between the drum & cover there are 2 metal clips holding the top down. Swing the top up and remove the front panel. The motor is right in front on the lower left. Let me know if this helps and thank you for using FixYa!
Jan 22, 2009 | Maytag HAV3460AWW Top Load Washer
Maytag washing machine will not drain model number lat36ooaa
Check drain hoses and pump for blockage. These are usually located under the tub so you will have to remove the covers. If not then the pump may be bad. MM85
Jul 27, 2008 | Washing Machines
Maytag LSG7806A Front Load Stacked Washer / Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
