Question about Philips DVP642 DVD Player
How to fast forward on an emerson tv/dvd combo with no remote
SOURCE:
  • 34 Answers
SOURCE: i need codes for my direct tv box and rca tv .vcr/dvd combo
MAGNAVOX ................................ 0247
DIRECTV .......... 0863 0864 0564 0763
................. 0963 0259 0260 0263 0962
....... 0664 0065 0265 0465 0765 0866
....... 0966 0367 0567 0362 0563 0765
Posted on Jan 29, 2009
SOURCE: i need codes for my emerson dvd/vcr combo using a
need codes
Posted on Mar 06, 2009
swmmwg
  • 11 Answers
SOURCE: need 13'' magnavox tv/dvd combo code for dish remote
To find the right code first click here.
Next click on the "Remote Controls" section.
Select the type of remote you have (based on the receiver model) to view the remote control users manual.
Hope this helps!
Posted on Mar 16, 2009
Herb Box
  • 68 Answers
SOURCE: codes for emerson combo
TV/VCR Combos
Where the code is listed as [### ###] the first is for the TV and the second is
for the VCR. Otherwise just the one code operates both the TV and the VCR.
EMERSON . 0324 0924 0027 0028 0128 0228 0632 0134 [0505 0826] [0316 0626] [0316 0327]
SOURCE: i need codes for a pilips universal remote to a symphonic dvd-tv combo
im after the users manual
Posted on Feb 02, 2010
What are the codes for emerson combo t.v. d.v.d.
Found this online. This is a "One For All" URC 8820.
The exact setup code is TV 1886. The newer version 8820N has this code. The older 8820B00 does not have this code, or anything similar. The only UEI remotes with TV 1886 are the OFA URC-8820N, 10820N, and RCA RCRP05B.
BTW, from hifi-remote.com, the TV/DVD combo is made by Funai, and uses NEC1 132.224.
Sylvania/Emerson/Funai : Remote Part# NF602UD
TV/DVD Combo's: FXV8266, LD155SL8, LD200EM8, LD200SL8
May 28, 2015 | Emerson Televison & Video
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Emerson tv/DVD combol
Hello
Sorry. There is no setup codes for Emerson TV/DVD combo with URC-3021 remote control. The only one code is there and is for Sylvania TV/DVD combo; and it is [0675]. OK.
Jul 31, 2011 | One For All URC-3021 Remote Control
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 12, 2009 | RCA Universal Remote 3 Device Remote...
Emerson tv dvd combo lost remote is there any way to program with out remote
hey Sweet
sorry no! but you can order an orignal replacement remote from here www.remotes.com and that wikk fix your problem!
Please rate answer!
Thank You!
Jan 26, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Direct Tv & Emerson Jumbo
I have an Emerson Combo Model EWC19T3 and a Emerson DVD/Vidio remote that is not working. I desire it to turn on and off the TV, raise and lower the volume and go to mute.
The only information inside the remote is listed below:
342;01HB;x3 Triple Combo;BNE200F01011;NECIC;sum3AA;ECR6:15v;N9353UOBW012
The TV is hooked up to Directv, the remote has new batteries
My email: Alank@netnitco.net
Name Alan C. Keller
Jun 17, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Remote codes
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
thats pdf i got my info off of
May 10, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
No code for the Emerson tv, dvd combo, model #LD200EM8
i have a remote and i can't find or program it to my tv combo tv/dvd
Jan 14, 2008 | Televison & Video
Philips DVP642 DVD Player Logo
249 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
