Question about Google Finance
Squirrel deterent keep squirrels from the garden and near the home
22yooper
  • 828 Answers
SOURCE: Mod ASU24C1
If the blower is made of plastic it does not have a set screw. You most likely need a new squirrel cage. They are formed to the shaft and have a compression ring that holds them in place.
Posted on May 29, 2008
SOURCE: Need to purchase new fan (blades only)
Part number for the fan blade is CRCFD5303-010
Posted on Aug 10, 2008
  • 14 Answers
SOURCE: Air conditioner/furnace squirrel cage fan remains running when th
probably the fan switch stuck on the fan combination control or improperly adjusted. Turn power off, remove red wire on the relay from the fan motor. Isolate so no short will happen and turn power on.The motor should not run. The fan relay could stick also. You will have to use a volt meter and see if there is voltage on the coil terminals on the fan relay. Put 1 lead to ground and touch only the terminal for the coil on the relay with the other meter lead.It should not have 120volts. If it does it is not the fan relay but possibly a limit sending power to the relay. Try that first thank you J
Posted on Dec 19, 2008
  • 21 Answers
SOURCE: Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
Posted on May 05, 2009
heatman101
  • 43501 Answers
SOURCE: sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Posted on Mar 25, 2010
Tip
How do I keep squirrels from eating my sunflowers?
Give the squirrels another source of feed/seeds.
1.Give the squirrels their own feed away from the location to which you will be growing the sunflowers.
2.Do this before growing the sunflowers. This will get the squirrels in a pattern and to a location away from your sunflowers.
3.Keep the squirrel food container (s) full at all times. If thesquirrels are full they will not have reason to eat the sunflower seeds.
Squirrels would rather eat peanuts, seeds, oats, breads, and/or what ever you want to give them over your sunflower seeds.
** To get the old squirrels away from a location they occupy now, is to train them away from it.**
Gradually move their food source away from any location they go to now.
Once you have them following the food, keep moving it until the foodsourced is in a location you would prefer the squirrels to go to forfood, rather than the squirrels eating your sunflowers....
Good Luck!
Hunnybunny11
on Sep 06, 2010 | Garden
Squirrel cage on 95 GMC Sierra truck noisy
tell the squirrels to quiet down
Apr 22, 2015 | GMC Cars & Trucks
How remove squirrel cage for heater
usually unbolts from the firewall . maybe a squirrel stored some nuts in the cage
Apr 22, 2015 | Cars & Trucks
I have a 1988 Nissan pickup, when I let out on the clutch to take off, it quits every time.
Dose the motor stall or dose the drive line lock up,more info needed.
Jul 19, 2014 | Cars & Trucks
Simple facts about squirrels
Their mother's milk, after that, same as the adult squirrels.
Jun 07, 2014 | Washing Machines
Squirrels chew rubber propane hose on my weber grill
cu the same length as gas hose from a piece of garden hose. cut the garden hose lengthwise and put that over the rubber hose. the garden hose is not rubber it has a soft plastic wich they probably will not like the taste of. kind of like the smell of the water when you first turn it on on a hot summer day.
Nov 13, 2012 | Grilling
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
1998 Dodge Ram 1500 Squirrel chewed through wires...
I bet that squirrel won't need any laxitaves for awhile. You are going to end up match and soldering, or just taping like color wires no mater what venue you take. The salvage yard is your best bet. Are you reffering to the area where the three relays are mounted?
Aug 25, 2009 | 1998 Dodge Ram 1500 4WD
Finance Logo
Top Google Finance Experts
Bill Boyd
castletech
castletech
Are you a Google Finance Expert? Answer questions, earn points and help others
