Question about Craftsman Garden
Will 42 inch bagger fit my 46 inch lawn tractor?
Craftsman lawn tractor baggers
5 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Why does the craftsman garden tractor model no.
I modified my John deere with a chute from another mower into my cart, It works great and picks up 10 times more trash than regular bags, you have to use the pick up blades, I just fill up the trailer, and dump the whole thing in the burn pile. Then go get some more. Believe me, i could run all day and not clean the whole yard. The pick up blades have some power but they do get clogged now and then, i just unhook it from the deck and dump it out and get going again. Hope this helps.
Posted on May 08, 2010
  • 110 Answers
SOURCE: Our craftsman garden tractor model no. 27603 doesnt fit a bagger!
ALL craftsman side-discharge tractors can accommodate a collector. If you can't get one specifically for your model, a universal one will fit.
It takes the form of a couple of plastic bins fitted to a frame that is mounted on the towing eye on the back of the tractor. A large diameter tube runs from an adapter 'boot' that fits over the discharge opening, to the bins on the back.
I'm in the UK, but we sell loads of these kits. SInce they come from the States, it shouldn't be a problem.
  • 4961 Answers
SOURCE: craftsman lawn tractor cuts off when you engage the blades
You might want to post this in the lawn mower section.
Posted on Aug 19, 2012
  • 2239 Answers
SOURCE: I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Posted on Oct 14, 2012
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
How to install a Husqvarna leaf bagger
The bagger installs by using the supplied bracket on the rear of the tractor. Mount the frame of the bagger onto the bracket. then connect the discharge tubes using the spring connecters. Flip open the lid and slide the bags into the frame.
Sep 04, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I was given a bagger for a husqvarna YTH20K46 riding mower. the bagger has a square base that looks like it should bolt to the back of the mower fram, but the four hole in the bagger attachment dont match...
It is made by AYP, how about you use google, find their website, purchase or download an illustrated parts breakdown and manual for it. This way you learn to help yourself. You are asking someone else to do for you what you can easily do for yourself. Hand a man a fish or teach a man to fish.
Mar 18, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I just purchased a poulan xt 38" riding mower and am wondering if this is the correct bagger for this. My model # is PXT12538.
If your tractor is 2006 or newer then yes this is supposed to fit. This bagger will also fit some craftsman mowers.
Jul 22, 2010 | Husqvarna #QCT38 960720001 38" Dual Bin...
May 07, 2010 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
