Question about Miele Washing Machines
Miele drum not spinning, clicking noise
Mielie prestige plus 6 washing machine suddenly stopped working after we moved it. The drum is not spinning and there is a little clicking noise. I cannot hear the motor / but maybe it is running.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
  • 1294 Answers
SOURCE: SIEMENS WXLM112GB FRONT LOAD WASHING MACHINE
Perhaps the exit hose behind your machine is not at the correct height, about 3 feet from ground. Your pump pumps the waste over this height, into your standpipe or sink; check this out.
Posted on Feb 13, 2008
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
While drying the drum makes suddenly a big noise and shakes a lot
Hi
Distribute the load of clothes when you put it in. Make sure they are balanced properly. If it's thumping during the spin cycle, stop it, open it up, move some clothes from the fuller side to the less full side, and see if that helps. Replace the springs inside the machine which suspend the washing drum. Open it up, take a look of it. Perhaps they're all saggy and this is permitting excessive vibration.
Put something under the machine to stop it from transmitting the vibrations to the floor of the house. An old sock folded several times and placed under each of the four feet may help. Rubber or foam will also work. Also, make certain the machine is level from front to back and side to side. Most washing machines have a large weight attached to the drum, usually a concrete block. It's supposed to prevent too much vibration. Check that one or more of the bolts holding it on haven't come loose.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Miele Novotronic Premier 500 Front Load...
Have a KitchenAid Prestige Top Load Washing Machine (Model: KAWs677EQO). It makes noise during the spin cycle and the drum moves when it comes to a complete stop after the spin cycle. Otherwise, it works...
I had the same problem 1 month ago, its probably the motor coupling for the direct drive. Its a small rubber Ring + a plastik drive. Its easy to change and not expensive.
Here the link for the part
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
May 01, 2010 | KitchenAid KAWS750L Top Load Washer
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
